A few turbo questions |
Oct 31, 2011 - 10:23 PM |
Enthusiast Joined Oct 30, '11 Currently Offline Reputation: 0 (0%) |
Hello, I was reading the stickys on turbos and I've been searching but I can't find this info. I am looking to boost only 5-8psi and I was wondering if I would need to upgrade my fuel system or not and also how much power do you guys think I'll get off of that. Also I have the 5sfe
Nov 1, 2011 - 12:24 PM |
depends on the turbo. you are making a very common turbo noob mistake. 7 psi on turbo A is nothing compared to 7psi on turbo B. for example on my Supra at 15psi i was making 450HP on my old 62-1 turbo. when i upgraded it to a T72 at the same boost level i was making 575HP.
now to answer your questions, YES you MUST upgrade your injectors. a very simple turbo system is use the stock 3S-GTE turbo and manifold, supra 310 injectors and the 3S-GTE MAP sensor. -------------------- 2001 Celica GT-S Turbo
Nov 1, 2011 - 12:51 PM |
Nov 1, 2011 - 1:35 PM |
I read through that and it didn't say you needed injectors or anything that's why I'm asking haha thanks tho depends on the turbo. you are making a very common turbo noob mistake. 7 psi on turbo A is nothing compared to 7psi on turbo B. for example on my Supra at 15psi i was making 450HP on my old 62-1 turbo. when i upgraded it to a T72 at the same boost level i was making 575HP. now to answer your questions, YES you MUST upgrade your injectors. a very simple turbo system is use the stock 3S-GTE turbo and manifold, supra 310 injectors and the 3S-GTE MAP sensor. I was gonna go with a much smaller turbo so there isn't much lag idk which one I'm gonna get yet tho |
Nov 1, 2011 - 1:51 PM |
I read through that and it didn't say you needed injectors or anything that's why I'm asking haha thanks tho first link from where i sent you yields: QUOTE EDIT!!! 315CC injectors are TOO SMALL for use in a turbo 5sfe. 460cc rx7 injectors are a drop in replacement and are discribed later in this post!!!
This post has been edited by playr158: Nov 1, 2011 - 1:52 PM |
Nov 1, 2011 - 2:38 PM |
I read through that and it didn't say you needed injectors or anything that's why I'm asking haha thanks tho first link from where i sent you yields: QUOTE EDIT!!! 315CC injectors are TOO SMALL for use in a turbo 5sfe. 460cc rx7 injectors are a drop in replacement and are discribed later in this post!!! Ok now I found it haha. Do you think 550cc would be good? |
Nov 2, 2011 - 6:45 PM |
Can you use Turbo Supra injectors for a 5sfte project? I found some for really cheap on ebay
Nov 22, 2011 - 12:09 PM |
Enthusiast Joined Nov 21, '11 From Saint Lucia Currently Offline Reputation: 0 (0%) |
With the addition of any turbo to any NA engine fuel mods are mandatory. Bare minimum I would do 315 injectors and 2 bar map sensor,
option 2: is stock injectors and 10:1 or 12:1 fmu. Option 3 : safc and bigger injectors Option 4 : piggyback or standalone A walbro 190 lph or 255 lph pump is also a really good idea. 5,8,10 psi , it doesn't matter, you are inducing more air so therefore you need more fuel. |
Nov 22, 2011 - 12:17 PM |
The 315cc supra injectors are only good for under 200whp setups.
I would really stay away from the fmu setups, they put a lot of strain on your fuel pump, and one little hiccup is a blown motor with em. Get some 390-460 cc injectors for a sub 300whp setup, with an safcII or emanage ultimate. And for bigger goals than that, a full ems is your best bet. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Lo-Fi Version | Time is now: November 27th, 2024 - 1:52 AM |
