Enthusiast ![]() Joined Sep 22, '10 From pomona, ca Currently Offline Reputation: 1 (100%) ![]() |
i will be using the apexi neo and aem eugo WBo2 to tune my 5sfte, does anyone know what i can use to log the info while im tuning. for example, free software, etc. or what would i need, some kind of cable for my laptop??? or should i do this the ghetto way, just use a camera to record my rpm's and wideband gauge? and playback slowly to make adjustments lol
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) ![]() |
in the manual, it shows one way using the hyperterminal (i'm sure you read that already tho): http://forum.aempower.com/forum/index.php?...9.0;attach=4370
This post has been edited by purplegt4: Nov 18, 2011 - 3:40 PM |
Video camera is your best bet. you can use hyper terminal to do a basic log, but it will be pretty much useless without an rpm reference to go along with.
thats where the zetronix WB setup shines, its got great datalogging capabilitys, im not sure if the AEM can do it the same way, have you checked the manual.
Got the neo without the manual lol I guess I can start with the camera n go from there. But ill make some research on the zetronix wb. Thanks guys
thats where the zetronix WB setup shines, its got great datalogging capabilitys, im not sure if the AEM can do it the same way, have you checked the manual. It cant unless you have their ecu to go along with it. ![]() This post has been edited by lagos: Nov 18, 2011 - 8:16 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() Enthusiast ![]() ![]() ![]() Joined May 4, '05 From western MD/NOVA Currently Offline Reputation: 2 (100%) ![]() |
i know that you are set with these two, but if that is not enough, you could always use an MS2 to datalog (cheaper option) or froget about the Neo (have never seen great things about it, and more about it limitations), and go for a Trust Ultimate E-manage, as far as a data logger it has GREAT wide list of options and tuning ability.. spend some time on MR2OC.com and if you havent yet ready through there stickied 5sfte threads, ALOT of great info there.
Lo-Fi Version | Time is now: February 13th, 2025 - 6:17 PM |
