> Iridium vs V-power
post Dec 20, 2003 - 11:50 PM
hyp3rk1d
Joined Sep 22, '03
I went to my local auto shop today and i was planning on purchasing NGK Iridium plugs.. they said they didnt have any of them but they had NGK V-power.. what is the difference and should i get them or no?? if not where can i get NGK Iridium plugs?
Replies (1 - 17)
post Dec 21, 2003 - 12:16 AM
95STHATCH
Joined Jun 21, '03
From FRANKFORT,KENTUCKY
I just replaced the old bosch platinums that were in my 95 st last weekend with v-power ngk. There were a huge difference in power ,I don't think iridium is all its cracked up to be anyways ,at least in our motors. Try to stay away from bosch platinums cause they are a hot spark plug,they don't last long in economy motors.
post Dec 21, 2003 - 1:34 AM
snadman
From Minnesota, USA
The iridiums will last longer and offer a real high powered spark with a lower temperature than the Bosch Plat 4's. The V-Power are basically what I sell to customers day in and day out that come in for NGK spark plugs. V-Power is basically the standard NGK plug, except it has a bit better design that allows quicker burning of the AF mix. You can read about the V-Power here and then click on the Standard, Platinum, and Iridium on the side to view the differences. The V-Power is somewhat like what would be OEM in our cars.
And the reason 95STHATCH got a noticeable difference, very very slightly nitceable mind you, is because as he stated...his Bosch plugs were OLD. Brand new the Bosch plugs should produce more or equal power compared with the V-Power one's brand new. But yet, the Bosch's wear much quicker and aren't meant for our cars. The standard way to find it goes like this...
Ford - Autolite spark plugs
GM - Champion
European (BMW, VW, etc.) - Bosch
Most Japanese Imports - NGK
These are typically that brands that come stock with the car from the factory, and always should be replaced with these unless the substitute is something better than doesn't run at a hotter temperature than the OEM ones. This is because after a certain temperature, the hotter the plug gets...it's eficiency decreases.
Hope this helps. Better have, cuz my work (NAPA) gave me 3 hours of pay to go to a 3 hour seminar on the ignition system.
This post has been edited by snadman: Dec 21, 2003 - 1:35 AM
95 Toyota Celica GT
02 WRX --> This is for speed
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- Alpine Type S Rear Fills
- Alpine M605 on each Type R
- Phoenix Gold wiring
- Alpine CDA-9855 Head Unit
- Alpine Amp link
post Dec 21, 2003 - 2:29 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
i need new plugs as well.
im going to buy the coldest plugs i can and see what difference it makes on my car.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Dec 21, 2003 - 5:25 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
V-Power, baby...that's all I use...IMHO, it's the best plug for turbocharged engines. I used Bosch Platinum 4 when my car was NA and they really sucked...good idle but I lost power. Now I use grade 8 V-Power plugs...they're very cold and the 7A-FE loves them smile.gif
This post has been edited by OOBE: Dec 21, 2003 - 5:28 PM
post Dec 21, 2003 - 5:28 PM
hyp3rk1d
Joined Sep 22, '03
So i guess ill get the v power smile.gif thanks for all the info guys
post Dec 21, 2003 - 5:33 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (OOBE @ Dec 21, 2003 - 2:25 PM)
where can i get me some of those?
post Dec 21, 2003 - 5:35 PM
hyp3rk1d
Joined Sep 22, '03
Advance Auto Parts..
post Dec 21, 2003 - 6:00 PM
edo17982
Joined Dec 21, '02
From Italy
I actually have Denso iridium IK27 plugs with MSD 8.5mm wires and the engine runs quite good.
In heavily modded engines the choose of the plug is very important but in stock engine the plug is relative, the important thing is to choose the right heat range!
I suggest iridium for the nature of material: it's much harder and stronger than silver or platinum BUT the spark energy is lower cause it's less conductive.
post Dec 21, 2003 - 7:30 PM
hyp3rk1d
Joined Sep 22, '03
ne more for v-power?? lol
post Dec 22, 2003 - 12:19 AM
OOBE
Joined Aug 30, '02
From San Juan, PR
V-Power grade 8 for 7A-FTE...I went through 10 sets of them in 1 day...they're like $12 or less. biggrin.gif
post Dec 22, 2003 - 2:30 AM
97GTinKC
From KC
GM - Champion
Dont let GM hear you say that, they actually use AC (Delco) spark plugs,
Chrysler used the Champions,,,
And stick with the recommended heat range or maybe 1 range colder if you drive hard, All the heat range is, is how quickly the plug dissipates(?) heat. too hot and the electrode stays red-hot and you get pre-ignition (Very bad)...too cold and you dont keep the carbon and other junk burned off the plug and get mis-fires. Colder plugs will have a short, fat center ceramic electrode post to get the heat to bleed off into the cyl head quicker, while a hot plug will have a long, thin center ceramic electrode post to let it stay hotter.
post Dec 22, 2003 - 3:07 AM
ST-204
Joined Dec 21, '03
From Lynnwood, WA
So do u guys mean the NGK Iridum spark plugs are the best for our Celica??
By the way, how about the Splitfire one ar??
Is it also good for our car? Pls give me some advise for buying the spark plugs, coz I also gonna get it lately.
post Dec 22, 2003 - 7:04 AM
hyp3rk1d
Joined Sep 22, '03
OOBE so what plug should i get for my 7afe?? V-power... is there different grades?? if so what should i get?
post Dec 23, 2003 - 12:05 AM
95STHATCH
Joined Jun 21, '03
Like snadman said the iridiums are quality plugs so they will last longer. NGK v-power won't last as long as iridiums but they are good plugs. You will notice a conciderable pick-up no matter what you use "IF" you haven't changed the plugs in a longgggggggg time or have never changed the plugs.You won't be beating vipers or nothing because you changed your plugs but you will definately notice the difference.
post Dec 23, 2003 - 1:09 AM
snadman
From Minnesota, USA
QUOTE (97GTinKC @ Dec 22, 2003 - 12:30 AM)
GM - Champion
Sorry, I guess I'm referring to what we sell at Napa. You are correct on that, just that we don't sell AC Delco's, so we sell Champions for all GM vehicles as well as Chrysler. :-D Thanks for the correction.
95 Toyota Celica GT
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- Alpine Amp link
post Dec 23, 2003 - 7:13 AM
hyp3rk1d
Joined Sep 22, '03
Looks like ill be gettin some V-power
post Dec 24, 2003 - 11:19 AM
hyp3rk1d
Joined Sep 22, '03
Lo-Fi Version Time is now: November 28th, 2024 - 7:47 PM
