> misfire
post Dec 12, 2011 - 12:56 PM
jccelica
Joined Nov 26, '11
From Farmington, Ny
My car has a misfire so I unplugged each one of my injectors one at a time with the car running and noticed a difference in every cylinder except for cylinder 4
Replies (1 - 5)
post Dec 12, 2011 - 8:00 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
Cyl 4 is misfiring
could be a plug wire, plug itself, or less likely the injector or wiring
post Dec 15, 2011 - 6:51 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
Agreed, pull plug #4 and then check for spark.
post Dec 18, 2011 - 1:30 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
If no spark from the plug, take the plug out, and do the ole (rubber handle) screwdriver and 1" from the engine trick to see if the spark jumps. If no spark, just change the wires, plugs, cap and rotor and be done with it. It probably needs to be done if it's been a while anyway.
This post has been edited by RabidTRD: Dec 18, 2011 - 1:30 PM
post Dec 23, 2011 - 11:43 PM
jccelica
Joined Nov 26, '11
From Farmington, Ny
thanks for the advise the plugs are kinda new not that old and I just did the wires gonna do the cap and rotor next
post Jan 2, 2012 - 11:06 PM
justin3
Joined Sep 27, '10
From Laredo
I just started that problem today, check engine came and its a misfire, any updates on what it was?
This post has been edited by justin3: Jan 2, 2012 - 11:06 PM
Lo-Fi Version Time is now: November 23rd, 2024 - 7:33 AM
