projectors modification |
Dec 25, 2011 - 4:55 PM |
Enthusiast Joined Nov 13, '10 From Calgary Currently Offline Reputation: 0 (0%) |
is it necesary to modify them once you have them , or can i just directly replace them, i doubt everyone with them
has done the mod for lhd use |
Dec 25, 2011 - 5:57 PM |
Enthusiast Joined Apr 17, '10 From Maitland, NSW Currently Offline Reputation: 3 (100%) |
It depends on a few things:
You may, blind the opposite side of the road resulting in a crash, or a fine off police. It will help you see better on the road, but its more for safety reasons. If your not running HIDs you could get away with it probaby. -------------------- |
Dec 25, 2011 - 6:27 PM |
you could also just make them point a little bit lower too
Dec 25, 2011 - 7:12 PM |
Dec 25, 2011 - 7:42 PM |
Enthusiast Joined Jan 8, '09 From Netherlands Currently Offline Reputation: 54 (100%) |
In the Netherlands, we have to convert them to LHD to be road-legal, so that's the main reason why I converted them.
Modification is easy but it just takes some time. Here's a short how-to of my conversion. My new projectors Take off the lights and all rubber parts. Put them in the stove: 10 minutes at 120 degrees Celsius Take off the glass The part of the projector that has to be converted Cutting the metall. I used a DREMEL with a grinding wheel. Re-install the projector. Put it back into the oven so the glue becomes soft again > it's easier to re-install the glass. I used this glue The result I installed Pilot HID, H1 6000 in lowbeams, HB3 6000K in highbeams and H3 6000K in the foglights. -Roy This post has been edited by RoyO: Dec 26, 2011 - 5:09 AM |
Dec 25, 2011 - 9:03 PM |
ok thanks a lot man, really helpful
Lo-Fi Version | Time is now: November 23rd, 2024 - 12:01 PM |
