> speed limiter, how to bypass it
post Jan 21, 2003 - 4:12 PM
trd94cel
Joined Oct 21, '02
i saw posted somewhere that the a'pexi rev/speed meter bypasses the speed limiter.
does anyone know if our car is a fuel cut off?
when i was lookin at the wiring diagram you cut this one wire,feed into the unit and
back out. if that was true could you just cut that wire?
does any have the ecu wireing diagram fo a 94 st
thanx
ryan
Replies (1 - 9)
post Jan 21, 2003 - 4:17 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
I don't have a 7afe but the 5sfe and the 3sgte have limiters so I bet you do to. One way to check if you have a fuel cut off is redline, unless I'm missing something finding out if you have a cutoff should be easy for you to do, unless your talking about something else.
But I believe there is a (don't quote me on this) yellow wire that if cut disables the fuel cutoff but I'm not sure- so don't go cutting wires just yet.
post Jan 21, 2003 - 4:40 PM
94celicaguy
Joined Nov 11, '02
the fuel cuts off at 135 mph. i found this out by spinnning through 5th gear in ice a couple nights ago.
post Jan 21, 2003 - 10:13 PM
celicakid84
From New Jersey
the fuel cutoff on the 7afe is between 118 and 120 mph.
post Jan 22, 2003 - 9:34 AM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
QUOTE (celicakid84 @ Jan 21 2003, 08:13 PM)
i know i cant go over 120 at least almost 120
i got scared
weird tho since i drive 100 mph no problme then i hit 110 then it starting to be a rush then 115 holy bejesus biggrin.gif
oh well not like im gonna hit 120 in a strip anyways
i only go up to 80 mph in a 1/4 mile
post Jan 22, 2003 - 12:09 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
once I was going up against a cobra doing 145 in my old gt no cutoff
post Jan 25, 2003 - 10:26 PM
hiflytsi
Joined Jan 9, '03
From Concord, NC
I got my gt up to 124 and it was struggling there, and when i was slowing down, I saw a cop up on a off ramp and then he came right after my ass, gave me a ticket for reckless driving and speeding. Luckily he only caught me while I was slowing down and he got me at 98. Licensce still pending... rolleyes.gif
post Jan 26, 2003 - 12:48 AM
slowceli
Joined Oct 31, '02
From grants pass oregon
my 94 st cuts off at 115mph. any body know how to get rid of this?
post Jan 26, 2003 - 2:18 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
I dont know about the fuel cut off bypass but you can bypass the fuel pressure limiter. alot of people with 3sgte's do this.
Get a couple inches of 10 gauge electrial wire
2 spade connectors
Attach on connector on each end of the wire
locate your fuel relay fuse and remove it
plug in your wire where the relay was.
What this does is when you slam on the gas your fuel pump will not drop its pressure right before it jumps up to full Psi.
The only real downfall to this is that if your in stop and go traffic... traffic jam.. the car will run really rich.
but for something that takes 5 mins to do, gives up to 5hp and can be returned back to stock its worth it
99 project version 3.0.. hello SEMA 2010 =)
post Jan 28, 2003 - 1:43 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
QUOTE (NEVERSTOP @ Jan 26, 2003 - 12:18 AM)
2 spade connectors
yo NEVERSTOP tell me more about this! Is it posible to do on ST?
<<<<<< DCw / JDMart >>>>>>>
Lo-Fi Version Time is now: November 28th, 2024 - 6:02 AM
