![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 7, '07 From Corpus Christi, TX Currently Offline Reputation: 7 (100%) ![]() |
So my gf's celica st speedometer is not working. All the other gauges work fine. I replaced the speed sensor with a brand new one thinking it was that but its still not working any ideas?
-------------------- From Japan to Texas my st202 follows me.
![]() Being different from every angle of the word, leading the Revolution (TOYOTA NATION) The RHD st202 that made it from Japan check it out. http://www.6gc.net/forums/index.php?showtopic=78103 |
bad gauge?
All the gauges are fine tho, RPM, water temp, fuel, are all fine.
But the speedometer isn't working, which is what I'm getting at. If the speedometer was working then replacing the speed sensor would have fixed this. Assuming of course the speed sensor has power to it and no wires are damaged or fuses blown. But hey, what do I know?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) ![]() |
it could be something in the wiring cause i tried to bypass the whole governor thing with the speed to only realize that i cut the wire that makes the speedometer work. luckily i had it on a switch lol
But the speedometer isn't working, which is what I'm getting at. If the speedometer was working then replacing the speed sensor would have fixed this. Assuming of course the speed sensor has power to it and no wires are damaged or fuses blown. But hey, what do I know? Well I just purchased a gauge so, maybe/hope ur right that it is the gauge, keep u updated bro. Thanks. -------------------- From Japan to Texas my st202 follows me.
![]() Enthusiast ![]() ![]() ![]() Joined May 4, '05 From western MD/NOVA Currently Offline Reputation: 2 (100%) ![]() |
Lil-joe101,, so she got the car like that? as in the speedo not working, and am i to assume correctly that she got the celi from Mkernz22? so also to assume that to be true. that the wires were cut?
with these assumptions.. this is my question. when she got the car were the wires just cut (as in not reatached), and any of them left just hanging? thing i am getting at is that if the car changed hands wile there were cut (and un-reassembled) wires there is a very good chance that it is the wires that are the problem, and not the actual speedo gauge, or the sensor... good luck. -------------------- |
Lo-Fi Version | Time is now: February 20th, 2025 - 12:31 AM |
