> "hose from hell" on gen III, possible replacement option..
post Mar 1, 2012 - 8:07 PM
match220
Joined May 13, '06
From Kaimuki, HI
I've already purchased the "hose from hell" for the oil cooler, but I've been thinking about what possible replacement options I can use in the future when I need another one. Two things have crossed my mind, high-temp rubber hose (that I can't seem to find with a 90 degree angle) or a silicone hose with a 90 degree bend.
The two options I can think of are either 275 degree rubber hose from Grainger.com or possibly a 90 degree silicone hose(also comes in blue!). The problem with the first link is it is not a 90 degree hose, so it will kink if you try to make it bend, plus I don't think that the 275 degree limit is high enough to protect from the exhaust temps from the nearby header. Also with the grainger hose, it's a 3/4 inch hose, I think the "hose from hell" is 5/8 diameter. The second link is a 90 degree bend silicone hose, and it is rated at 350 degrees. This temperature is better, but average exhaust temps are around 400 degrees. I know the hose won't see the full 400 because it is around a foot from the exhaust, but I'm wondering what approximate temps it would see. This hose is not even $20. What do you guys think? Anyone done this?
This post has been edited by match220: Mar 1, 2012 - 8:10 PM
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
Replies (1 - 3)
post Mar 1, 2012 - 9:24 PM
Neon90424
Joined Jan 19, '11
From Paraguay, Winchestertonfieldville
heat wrap the hose you buy.
post Mar 1, 2012 - 9:35 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (Neon90424 @ Mar 1, 2012 - 4:24 PM) *
I have the stock one, and it's already heatwrapped. Heatwrapped silicone hose might last very very long now that I think about it.
-Jay
post Mar 5, 2012 - 11:09 AM
mckenziejr
Joined Jan 29, '12
From toronto,ontario
get fire jacketing and it should be ok
Lo-Fi Version Time is now: December 3rd, 2024 - 1:33 AM
