jdm Projector, question about installation |
Apr 9, 2012 - 8:03 PM |
Enthusiast Joined Aug 17, '10 Currently Offline Reputation: 0 (0%) |
Hi guys
I have a jdm RHD 94 celica and I am thinking to buy jdm clear projectors. Is the wiring just plug on or the connectors will be different. I know I will need the electronic unit for the projectors but I don't know much details. |
Apr 10, 2012 - 1:51 AM |
what electronic unit, HIDs? If you are currently on H1 bulbs, no conversion, if you are not, you gotta do some wiring.
Apr 10, 2012 - 3:43 AM |
Enthusiast Joined Dec 16, '11 From The Netherlands Currently Offline Reputation: 5 (100%) |
Apr 10, 2012 - 8:08 AM |
what electronic unit, HIDs? If you are currently on H1 bulbs, no conversion, if you are not, you gotta do some wiring. Thanks for your respond. My headlights are all stock I never changed any of the bulbs since I bought the car, I don't know a lot about bulbs and I don't care really how bright will be or not. I am happy the way my headlights work at night so I only wan't the jdm for better look, so do you think I will need any wiring? Or is it possible to use the existing bulbs in a jdm projector? This post has been edited by marinos: Apr 10, 2012 - 8:18 AM |
Apr 10, 2012 - 9:09 AM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
You may just need to get different bulbs, because the stock are 9005 for the high beams, and I'm pretty sure the JDM high beams are a different bulb size (Check the electrical/lightint stickies, it will say which bulb in there)
But if the JDM highs do use a 9005 like the USDM highs, then it will simply be plug and play, no need to change any wiring. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Apr 10, 2012 - 2:15 PM |
You can plug your high beam bulbs in with no issues. The low beams use a different bulb- they use an H1 bulb instead of a 9006. You will need to either cut and splice your wiring to an H1 connector or make a plug and play wiring harness, as posted in the link provided.
http://www.6gc.net/forums/index.php?showtopic=81270 -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Apr 16, 2012 - 2:29 PM |
Thanks guys!!!!
Lo-Fi Version | Time is now: January 10th, 2025 - 12:39 PM |
