Trunk light not working. |
May 22, 2012 - 1:10 PM |
Enthusiast Joined Apr 22, '07 From Bay Area, California Currently Offline Reputation: 14 (100%) |
Changed the bulb and fuses checked. Any suggestions on what may be wrong?
-------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=- |
May 22, 2012 - 1:11 PM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
Just throwing this out there... but is the switch in the "ON" position?
May 22, 2012 - 1:12 PM |
It could be the trigger on the latch. Do your interior lights go on when the hatch/trunk is open?
May 22, 2012 - 1:13 PM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
Maybe the wiring came disconnected?
This post has been edited by jordisonjr: May 22, 2012 - 1:14 PM -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
May 22, 2012 - 2:02 PM |
Lol yes it's flipped on. No, the interior lights don't turn on. Sounds like its the trunk latch switch. Any idea how I check this?
Found a black wire which broke off next to the latch. If ur looking from outside the car, in it's on the left side when u look down on it. Probably the culprit:) -------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
May 22, 2012 - 3:23 PM |
Yes that black wire would be it haha
Just pop the back panel off and everything is right there This post has been edited by mkernz22: May 22, 2012 - 3:23 PM |
May 22, 2012 - 3:27 PM |
Enthusiast Joined Apr 11, '09 Currently Offline Reputation: 11 (100%) |
isnt this interior/electrical?
May 22, 2012 - 3:34 PM |
It's also maintenance.
May 22, 2012 - 3:48 PM |
May 22, 2012 - 10:33 PM |
Enthusiast Joined May 3, '11 From Ohio Currently Offline Reputation: 8 (100%) |
The trunk light is grounded through the cable that pops the trunk... take off your interior plastic to get to the latch. There is a small switch in there, but i've also noticed that when I take my cable off to work on the latch the light goes off and dims when I move it at all. So check that.... something grounding with that pop cable.
That is at least how mine works anyway. This post has been edited by ricochet1490: May 22, 2012 - 10:33 PM -------------------- |
May 23, 2012 - 10:56 AM |
Didnt even know people payed attention to what section stuff was posted in lol, I know I don't.
If you don't want to drounf it back to that steel cable that pops the trunk, im sure you could find some other sort of ground in the trunk, or a spot you could ground it to. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
May 23, 2012 - 1:50 PM |
Problem fixed. It was the broken wire:)
May 29, 2012 - 9:37 AM |
Enthusiast Joined Oct 17, '11 From Kent, WA Currently Offline Reputation: 0 (0%) |
Lo-Fi Version | Time is now: November 30th, 2024 - 7:54 PM |
