> Gear Oil change how-to?
post Aug 24, 2012 - 10:52 AM
Syaoran
Joined Jan 4, '12
From US
So I'm ready to do a gear oil change along with an oil and filter change, but the thing is I don't know where the plugs are exactly.
I tried making sense out of the BGB but I can't visualize it. Can I pour in the gear oil through the reverse light switch hole? (after removing the switch)
EDIT: also, how much gear oil should I use? I've seen 2.5qts and 3.5qts in different places... so I'm kinda confused. Using Synchromesh by Pennzoil
This post has been edited by Syaoran: Aug 24, 2012 - 10:58 AM
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
Replies (1 - 15)
post Aug 24, 2012 - 12:48 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
info is in the stickies.
God made man....
Everything else...
Made in China
post Aug 24, 2012 - 1:02 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
There is a plug on the bottom passenger side and a plug on the front near the top. I think they were something like 21mm on my 94 GT.
If the car is on a level surface then all you have to do is fill till it starts overflowing, if the car isnt level then its apx. 2.6 quarts though you may wanna double check me on that. Pennzoil syncromesh is what Im running(its fixed my 3rd gear shift) and I think 75w-90 is the viscosity.
post Aug 24, 2012 - 2:19 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (Special_Edy @ Aug 24, 2012 - 2:02 PM) *
So you've had no issues with the Synchromesh so far? How long has it been since? I've read around MR2 forums (lots more info) that the S54 likes MT-90 better but that Synchromesh will work.
Thanks for the info, I'll go and see if I can find the fill plug before removing the drain plug.
post Aug 25, 2012 - 8:48 PM
trdproven
Joined Aug 2, '05
From Guam
QUOTE (Special_Edy @ Aug 25, 2012 - 4:02 AM) *
hmm let me doublecheck that cus the tranny is on the driver side. im not too sure about this one unless someone recalls.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 25, 2012 - 9:58 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (trdproven @ Aug 25, 2012 - 9:48 PM) *
Kinda awkward but the tranny fill plug is facing downward 45* and the drain plug is parallel to the floor.
Fill plug is below the slave cylinder and the drain plug is right below the driver side axle.
post Aug 25, 2012 - 10:35 PM
trdproven
Joined Aug 2, '05
From Guam
something like that
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 25, 2012 - 11:07 PM
CRBCelica
Joined Jan 20, '10
From Twin Cities, MN
is penziol the best for our cars? 5sfe???
02 Celica GT- Garage Queen 2zz 6spd Swapped
96 Celica GT- Daily Driver
post Aug 25, 2012 - 11:56 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (CRBCelica @ Aug 26, 2012 - 12:07 AM) *
Pennzoil, Redline MTL, MT-90, Redline Shockproof Super Light Weight...
Basically use anything that is apt for soft metals or "yellow" metals as they call them.
post Aug 26, 2012 - 12:59 AM
Special_Edy
Joined Oct 29, '11
QUOTE (Syaoran @ Aug 25, 2012 - 9:58 PM) *
post Aug 26, 2012 - 5:12 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
yes its driver side, and there are two plugs that sorta blend in, but will stand out if you look hard enough. as stated before, drain out of the bottom plug fully, then fill the top plug on level surface until it overflows. it will take a LONG TIME but IIRC its almost 3 quarts.
my car does not shift well... Ive been using 75-90 IIRC but I may have to try this MT-90 From redline....
post Aug 26, 2012 - 9:35 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (easternpiro1 @ Aug 26, 2012 - 6:12 AM) *
Should I get vinyl tubing or can i squeeze the grease in using the spout that comes with it?
post Aug 26, 2012 - 9:59 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
if you want an easier life, i would get the long tube.... it takes forever for it to seep into the tranny, and you will be waiting forever if you just use the spout.
post Aug 27, 2012 - 9:32 AM
Special_Edy
Joined Oct 29, '11
QUOTE (Syaoran @ Aug 26, 2012 - 10:35 AM) *
There is a hand pump with a clear tube attached which will screw onto the top of the bottle. Its available at the local autoparts store for a couple bucks. Makes fillin trannys super easy
post Aug 27, 2012 - 10:27 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE (Special_Edy @ Aug 27, 2012 - 10:32 AM) *
REALLY?!?!? well i know what im gettin next!!!!! lol
post Aug 27, 2012 - 11:54 PM
trdproven
Joined Aug 2, '05
From Guam
theres also a funnel with a long tube and its a pretty big funnel, just fill it up heavy and it will eventually all go in a lot.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: February 22nd, 2025 - 3:13 PM
