> manual tranny whining...
post Sep 10, 2012 - 5:52 AM
BeachBum12
Joined Nov 7, '10
From Florida
Ok soo I just recently got rid of my system and with my new found lack of noise violating woofers I've notice my tranny whines abit when accelerating. I don't know how long its been doing it but I don't remember hearing it when I got my car six months ago and I a little worried lol. Any clue what's causing it??
Replies (1 - 13)
post Sep 10, 2012 - 10:18 AM
alltracman78
Joined Aug 9, '06
From Ma
In forward either a bad gear or bad bearing.
Does it do it in every gear or just one?
Whine is normal in reverse.
Have you checked the oil level?
This post has been edited by alltracman78: Sep 10, 2012 - 10:18 AM
post Sep 10, 2012 - 1:44 PM
Box
Joined Feb 23, '12
From Warrior, AL
If the oil hasn't been changed recently that you know of I'd say go ahead and replace it, since you're down there anyway just to check it.
2001 Miata LS 5-speed
post Sep 10, 2012 - 2:01 PM
mkernz22
Joined May 10, '10
From MA
It'll usually whine if you are in a higher gear at a low rpm and you try accelerating.
But do you mean when you take off from a stop sign?
post Sep 10, 2012 - 8:23 PM
alltracman78
Joined Aug 9, '06
From Ma
And it's the engine, not the trans. Too much load causes it to bog.
post Sep 11, 2012 - 4:48 AM
BeachBum12
Joined Nov 7, '10
From Florida
Yeah far as I know it does it in every gear from a complete stop on up, but it slowly gets quieter as I go through the gears. Maybe that's because the road noise muffles it?
I don't know if it's low on oil yet but I know there's no obvious leaks and about 3 months ago i replaced the oil when i had to put a new axle on the drivers side... If its not low could it be the gear oil i used? I put some Valvoline Synpower in her I think it was 75w-90 or something like that lol. I really appreciate the help dudes smile.gif
post Sep 11, 2012 - 7:12 AM
smkr3w
Joined Nov 29, '10
From Lake Havasu City, AZ
So when you say got rid of the system is that just the subs or everything including the amp? Alternator whine thru speakers could also be it..
post Sep 11, 2012 - 8:08 AM
alltracman78
Joined Aug 9, '06
From Ma
Easy way to see if that's it.
Rev the engine in N. If you hear the whine, it's not the trans.
MOST gear oil is pretty much the same thing and won't make much difference, as long as you have enough in there.
Even though you just filled it a few months ago, if you're having a problem it's a good idea to check it.
One major difference between the engine and transmission oiling systems is while the engine pumps the whole time it's running, the trans only pumps when the car is moving. So if you have a leak somewhere besides the bottom you may not see it until it's too late.
post Sep 11, 2012 - 8:39 AM
BeachBum12
Joined Nov 7, '10
From Florida
Yeah I got rid of everything when I traded it off lol but the whines definitely coming from the engine bay
Hmm I didn't know that lol this is my first stick shift so I'm new with the concept of how it works, how do I go about checking my fluid? When I filled it I just put 2.7l which was amount the auto shop guy told me to through a hole on top that I took out with a torques bit. But when I went out and rev it in neutral it doesn't whine at all. I'd love to buy a manual but the local shops around here haven't had any Celica ones when i skim though the aisle /=
*Edit* ok I hate sounding like a complete moron but I was just out messing with my car and it does whine while free revving but it's not quite as loud...
This post has been edited by BeachBum12: Sep 11, 2012 - 9:58 AM
post Sep 11, 2012 - 12:43 PM
alltracman78
Joined Aug 9, '06
From Ma
It may be one of your accesories [alt, pwr steering, ect].
You don't fill it through a torx plug, it's filled through a 24mm plug on the side [front, facing the radiator] of the trans.
And IMO you're best getting a factory manual [Toyota BGB]. Try ebay.
They're MUCH MUCH better than any aftermarket crap.
post Sep 11, 2012 - 1:19 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
maybe someone installed a dog box and gilmore pulleys while you werent looking tongue.gif
Mike W
269awhp / 273ft-lbs
post Sep 12, 2012 - 3:03 AM
BeachBum12
Joined Nov 7, '10
From Florida
Hmm that's sucks that's where the shop guy said I should put it in at... So just out of curiosity what's that plug on the top for?
I'll definitely be looking on eBay for one of those manuals lol I just got to wait till I get home so I can use a real computer I hate using eBay on my phone
haha that'd explain so much, my car goes through mood swings =p
post Sep 12, 2012 - 7:42 AM
delusionz
Joined Feb 11, '08
is that the spring loaded cap on the top? might be a pressure relief valve?
Mike W
269awhp / 273ft-lbs
post Sep 12, 2012 - 9:09 AM
BeachBum12
Joined Nov 7, '10
From Florida
Lol no I surprisingly know what that is, its a t55/60 torx key plug about 4 inches closer to the radiator to the right of the relief valve.
This post has been edited by BeachBum12: Sep 12, 2012 - 9:11 AM
Lo-Fi Version Time is now: December 3rd, 2024 - 10:56 AM
