> frames
post Nov 9, 2012 - 2:38 PM
danny1985
Joined Jul 29, '12
From tampa
just wondering what is the difference in the st204 frame to the st205 one if there is any
Replies (1 - 2)
post Nov 9, 2012 - 2:41 PM
richee3
Joined Jun 29, '08
From Denver
Off the top of my head, the trunk floor is different, fuel tank is under the trunk, AWD mounts, and some other small things but they're mostly the same.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Nov 9, 2012 - 3:28 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Somebody who has done the swap would be the best to ask, but from what Ive read the sheetmetal is a thicker gauge on the ST-205 and thus the body is stronger, more rigid and heavier. The driveshaft tunnel in the center of the floorboards is obviously different, though it may be simply the inclusion of driveshaft carrier-bearing mounts that make it different and not the size or shape, Im not sure. The most different section is the rear where the trunk and rear differential go. As richee3 stated, the entire trunk is actually a couple inches shallower(4" maybe, idk, but also with out a low spot for the spare) in order to make room for the fuel tank. The fuel tank was moved to make room for the rear differential which powers the rear axles.
This post has been edited by Special_Edy: Nov 9, 2012 - 3:33 PM
Lo-Fi Version Time is now: November 27th, 2024 - 7:33 PM
