Rubber surounds on Low beams. |
Dec 7, 2012 - 7:05 PM |
Enthusiast Joined Nov 30, '12 From Ohio Currently Offline Reputation: 0 (0%) |
Is there a good guide or picture that shows how those darn rubber rings go on the lights and what clips hold them?
I believe a see a right and left side so I think I have the right ring on each headlight, but the don't line up with the all the clips. |
Dec 7, 2012 - 8:14 PM |
I read on here a while back that rubber cement works wonders if you don't mind a permanent installation.
Dec 7, 2012 - 8:57 PM |
Enthusiast Joined Aug 23, '11 From kenton ohio Currently Offline Reputation: 14 (100%) |
I used black silicone on mine
Takes some time but you can get them to come off later if need be -------------------- 95 gt coupe, v6 swap weekend toy
99 gt hatch beams swapped wife's 94 st hatch my daily driver http://www.6gc.net/forums/index.php?showtopic=82235 n |
Dec 7, 2012 - 9:53 PM |
fyi, only one clip (located at the top center of the headlamp) hooks the rubber surround to the headlamp. the rest of the clips simply hook the glass to the housing (even though it doesn't need it). the rubber surround is glued on the glass by the factory.
Dec 7, 2012 - 10:45 PM |
Enthusiast Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
they only fit on one way too. so maybe u just gotta rotate them around until they sit nicely.
-------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Dec 7, 2012 - 10:52 PM |
fyi, only one clip (located at the top center of the headlamp) hooks the rubber surround to the headlamp. the rest of the clips simply hook the glass to the housing (even though it doesn't need it). the rubber surround is glued on the glass by the factory. That explains why the clips dont align! they only fit on one way too. so maybe u just gotta rotate them around until they sit nicely. I suppose I will give it a try this weekend.......they sure like to slip off regardless of what position they are in. lol Do you think if I buy new ones they will fit looser (the older rubber shrank or became less flexible??) |
Lo-Fi Version | Time is now: January 10th, 2025 - 1:49 PM |
