CEL on but can't get code |
Dec 15, 2012 - 5:36 PM |
Enthusiast Joined Jan 27, '08 From Mass Currently Offline Reputation: 6 (100%) |
I have a 95 st and it is now running very rough and misfiring. it won't go about 3000rpm as the ecu cuts the fuel. I have a check engine light, but when I short the e1 and te1 pins nothing happens. Is there another way to get the code?
Dec 15, 2012 - 8:22 PM |
do you turn the key to the on position when you do this?
Te to e1 is what you are supposed to jumper, so it should be working for you -------------------- 2001 Celica GT-S Turbo
Dec 15, 2012 - 8:25 PM |
Dec 15, 2012 - 11:20 PM |
something is wrong then. are you sure you are jumpering the right terminals?
Dec 15, 2012 - 11:46 PM |
Dec 16, 2012 - 1:05 AM |
that is possible. not common bit possible
Dec 16, 2012 - 12:00 PM |
Enthusiast Joined Oct 29, '11 From Haltom City, Texas Currently Offline Reputation: 1 (100%) |
Maybe she'll give it up after dinner and a movie?
Try TE2 and E1. TE2 is the advanced diagnostic port. |
Dec 16, 2012 - 3:00 PM |
Dec 16, 2012 - 3:07 PM |
Code scanner. Advanced Auto Parts and/or Autozone does free scanning.
Dec 16, 2012 - 5:36 PM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
Code scanner. Advanced Auto Parts and/or Autozone does free scanning. I took my car to AutoZone to get a free scan and they said they don't do it no more. At least the ones in Cali don't do it no more. I don't know about other states and stores. This post has been edited by ILoveMySilly97: Dec 18, 2012 - 3:15 PM -------------------- |
Dec 18, 2012 - 11:56 AM |
that only works on ODBII cars. this is a 95 so its ODBI
Dec 18, 2012 - 12:03 PM |
that only works on ODBII cars. this is a 95 so its ODBI There are still OBDI scanners. -------------------- 2001 Miata LS 5-speed
Dec 22, 2012 - 1:14 PM |
I figured I would post and update in case this happens to anyone else. After replacing my ecu the car runs great. No CEL and no misfiring nothing.
So long story short, if your pre96 celica throws a CEL and you can't retrieve it and all the sensor and voltages check out at the ecu, then it's time to replace the ecu. |
Lo-Fi Version | Time is now: December 4th, 2024 - 11:12 AM |
