Building the 7afe to handle boost, Need some assistance |
Feb 5, 2013 - 1:34 PM |
Enthusiast Joined Feb 5, '13 Currently Offline Reputation: 0 (0%) |
Hey everyone, I own a 94 Celica ST with the 7afe motor in it. I have 4k to throw into this car and want to redo to handle boost and hopefully generate some great hp with it. I have basically every piece of parts i need gathered but still need a little help on some topics. Here are the parts I have so far:
1) 4age forged pistons still keeping it at 9.0:1. 2) forged 7afe H beam rods 3) stock crank 4) Bored out cyclinders 5) t2 turbo kit 6) aem piggy back 7) boost gauge 8) colder spark plugs 9) 440cc injectors 10) 12.1:1 FMU 11) 255 fuel pump 12) wide band o2 sensor and gauge The thing ive been thinking about is, Do i need a different crank to handle the extra stress that i will be putting on this motor? some people online are saying its forged and the other half are saying its not forged. So does anyone know for sure which one it is?? I have no idea how much power i will be able to generate with this setup but it will be towed to the dyno shop as soon as the build is complete. Of course i wanna make sure everything is able to handle the boost ima be shoving into it. I have no idea on how much boost i will be able to run, hopefully 15psi or more depending on what the dyno people do. I have never turbod a 7afe before only did hyundai tiburons before this, but i did do tons of research on the 7afe, but still have some remaining questions. Also does anyone know what else will be needed to do to sqeeze the most power out of this motor as i can? without doing a swap of any kind. Also it will be nice to know if anyone has a similar build and see what kind of numbers they are generating. Thanks. This post has been edited by rapid36: Feb 5, 2013 - 1:57 PM |
Feb 5, 2013 - 2:20 PM |
Everything you will ever need to know
http://www.6gc.net/forums/index.php?showto...p;hl=turbo+7afe Dyno part is on page 16 You could get the same amount of power out of a 1mz for half the price ($2000). This post has been edited by mkernz22: Feb 5, 2013 - 2:24 PM |
Feb 5, 2013 - 3:21 PM |
Everything you will ever need to know http://www.6gc.net/forums/index.php?showto...p;hl=turbo+7afe Dyno part is on page 16 You could get the same amount of power out of a 1mz for half the price ($2000). Thanks for the link! im still reading on it, so far it seems to be a formula to how much power you can make, which is cool and needed, so thanks for that! Hopefully someone can answer the other questions i have now. But as i mentioned before im trying my best to stop from doing a swap. Plus i dont see how it will cost only 2k when i would have to buy forged parts for that, not to mention all the labor into swapping over computers and motor mounts. i believe the 1mzfe produces around 170hp??? not sure but i think thats what it had when i looked them up. if thats the case then a turbod 7afe with forged internals should go well beyond that, not to mention the weight difference between the motors. |
Feb 5, 2013 - 3:25 PM |
actually the 1MZ weighs about the same as a 7A-FE. if you do the swap like it did, using a 3MZ engine and 1MZ computer and some parts. i made 240TQ and 22HP. Its going to take some serious boost to get a 7A to do that.
Feb 5, 2013 - 3:31 PM |
actually the 1MZ weighs about the same as a 7A-FE. if you do the swap like it did, using a 3MZ engine and 1MZ computer and some parts. i made 240TQ and 22HP. Its going to take some serious boost to get a 7A to do that. a v6 weighing the same as a 4???? but Wow thats impressive!! Great job! , but a built 7afe with forged should be well within that range (or at least i would imagine so). of course it will have a proper tune and a fully built motor (despite the fact if i need a forged crank or not). But on the how to articles on here, under the "how to turbo your 7afe" the guy was running on stock internals and was running 14psi and he said he doubled his power, which should be 220hp, not sure how true that is. and so a forged setup should hold up to 300hp easy, granite having a great setup and all the right parts is a must. im hoping to at least push 250 with my build. |
Feb 5, 2013 - 5:34 PM |
Click the link to the thread I posted, you might end up spending more than 4k to build that 7a to make any decent amount of power
Feb 5, 2013 - 6:37 PM |
the 7A is cast Iron. the MZ is Aluminum. I can easily pick up the block of the V6, i almost drop my nuts picking up the 7A...Now imagine how heavy the 2JZ is.
Feb 6, 2013 - 11:16 AM |
oh ok, well i already bought most of the parts that i need (they are listed above) and i bought all the tools to put it together and what not, including the engine stand! and im only at 4.5k so far! just trying to see what else im missing before i pull out my motor and start redoing it. better to have everything mapped out before jumping into it. Thank you for the link! im still going through it
Not to mention that the 4.5k is including the clutch i bought for my tranny which is rated to withstand 400lbs of torque. Note: You can't just have a good motor you have to have everything else built up as well! or else its pointless having a great built up motor! Ill have to start a progress build on here as soon as i get all my parts! I think you all will enjoy it! This post has been edited by rapid36: Feb 6, 2013 - 11:20 AM |
Feb 6, 2013 - 12:09 PM |
tell me more about this transmission you have, what was done to it?
Feb 6, 2013 - 1:59 PM |
tell me more about this transmission you have, what was done to it? Just the stock tranny, that comes in the ST but put new seals in and put in a clutch kit that is rated to handle 400 torque, here are the specs that were listed with it: Part Number: TC2-XTR6 Application: 1ZZFE 2ZZGE 4AFE 7AFE Includes: - Includes pressure plate - Disc Included - ACT Stickers & Decals - Installation instructions Specs: - Torque Capacity (FT/LBS): 400 - Clamp Load Increase (%): 65% - Pressure Plate: T022X - Disc: 6212003 - Release Bearing: RB840 - Pilot Bearing: N/A - Align tool: ATK73 Pressure Plate: XT=Xtreme - Gives 50-120% clamp load increase - Has moderate to stiff pedal feel - Recommended disc: Street or Race Xtreme Spring Centered Race Disc: G6=6 PUCK (pad) - Increased torque capacity and spline life - Recommended for road racing and high power street racing - Very good durability and spline life - Quiet operation and reduced driveline shock - Has Harsh engagement and chatter |
Feb 6, 2013 - 3:06 PM |
Just because the clutch can handle up to 400hp doesn't mean that the transmission will. If the s54 for the 5s doesn't hold over 350hp, I don't think the 7a transmission will hold over 300hp, if that.
Feb 6, 2013 - 4:09 PM |
Just because the clutch can handle up to 400hp doesn't mean that the transmission will. If the s54 for the 5s doesn't hold over 350hp, I don't think the 7a transmission will hold over 300hp, if that. i totally understand lol. but im only looking to get 250-300 out of this build, so it looks like i will be ok. well we can only hope. |
Feb 6, 2013 - 4:57 PM |
I didn't know what your power goals were, but that should be easily doable!
Feb 6, 2013 - 5:50 PM |
I didn't know what your power goals were, but that should be easily doable! Thanks! glad to hear something positive! Hopefully i can push the 7a to get to that 300. I saw a guy with a corolla that has a 7afe in it, and he built the motor with forged parts and is running 21psi and getting 300hp at the wheels. If anyone wants the video link let me know!!! if so then ill post it on here for everyone to see. Dont message me though cause i may not answer, i dont really check it lol . But The guy in the video also wrote up a how to build your 7afe for handling boost. And thats exactly what im following but i still have the question if i need a forged crank or anything else to withstand the 300hp im trying to get out of this thing. Anyways im hoping this thread will be helpful for not only me but to others who are looking to do the same thing! |
Feb 7, 2013 - 4:11 PM |
Enthusiast Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) |
Transmissions don't handle HP, and cars don't produce HP.
With that said, I know of an MR-2 1ZZ turbo with around 300-320 whee torque with aftermarket LSD doing hard launches and using Nitto drag radials. He does 11.8s 1/4 mile. C-series transmissions are not weak by any means (except C60 which is the ****ty 6-gear that comes with the Corolla XRS or Celica GT-S; those break on stock 2ZZ power) He has never had to do anything to the transmission and it's been well over 2 years turbo, 260-280-320 wtq across its life. @OP: You should've fit an LSD if you had the transmission out. However since it's already done, the most important component in making power is the tuning solution. If you don't have proper tuning you can break even the best forged engine. This post has been edited by Syaoran: Feb 7, 2013 - 4:12 PM -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Feb 7, 2013 - 4:23 PM |
With that said, I know of an MR-2 1ZZ turbo with around 300-320 whee torque with aftermarket LSD doing hard launches and using Nitto drag radials. He does 11.8s 1/4 mile. C-series transmissions are not weak by any means (except C60 which is the ****ty 6-gear that comes with the Corolla XRS or Celica GT-S; those break on stock 2ZZ power) no they dont. they break from abuse. im still using the original 6 speed from my car thats 12 years old. I didnt even suffer from the 3rd and 4th gear grind that the early ones did. -------------------- 2001 Celica GT-S Turbo
Feb 7, 2013 - 4:27 PM |
Transmissions don't handle HP, and cars don't produce HP. With that said, I know of an MR-2 1ZZ turbo with around 300-320 whee torque with aftermarket LSD doing hard launches and using Nitto drag radials. He does 11.8s 1/4 mile. C-series transmissions are not weak by any means (except C60 which is the ****ty 6-gear that comes with the Corolla XRS or Celica GT-S; those break on stock 2ZZ power) He has never had to do anything to the transmission and it's been well over 2 years turbo, 260-280-320 wtq across its life. @OP: You should've fit an LSD if you had the transmission out. However since it's already done, the most important component in making power is the tuning solution. If you don't have proper tuning you can break even the best forged engine. Your right they handle torque but i am lost on what your trying to say about cars not producing HP, could you clarify this for me???? Also that's awesome to hear! Seems like I should do alright then. But yes your absolutely correct! A good tune is a must! I will be taking my car to a dyno shop to get it tuned as soon as I get this build complete. And now I never looked into a limited slip differential for these cars, that idea never even hit me, Could it be done to these front wheel drive celicas? specifically the ST?? |
Feb 7, 2013 - 5:12 PM |
HP is a measure of torque multiplied by the RPM where the torque measured is produced and then is divided by a constant of 5252. The formula for Horsepower looks like this:
(Torque * RPM)/5252 Horsepower is not what an engine produces, because an engine converts energy produced in the combustion into a mechanical force, and that mechanical force is applied in a rotation through the crankshaft, which in turn rotates other things like the transmission; this is also known as torque. -------------------- 1993 Celica GT Coupe - sold
Feb 7, 2013 - 5:22 PM |
HP is a measure of torque multiplied by the RPM where the torque measured is produced and then is divided by a constant of 5252. The formula for Horsepower looks like this: (Torque * RPM)/5252 Horsepower is not what an engine produces, because an engine converts energy produced in the combustion into a mechanical force, and that mechanical force is applied in a rotation through the crankshaft, which in turn rotates other things like the transmission; this is also known as torque. Very interesting, never knew that. |
Feb 7, 2013 - 6:16 PM |
HP is a measure of torque multiplied by the RPM where the torque measured is produced and then is divided by a constant of 5252. The formula for Horsepower looks like this: (Torque * RPM)/5252 Horsepower is not what an engine produces, because an engine converts energy produced in the combustion into a mechanical force, and that mechanical force is applied in a rotation through the crankshaft, which in turn rotates other things like the transmission; this is also known as torque. very well explained. HP is a imaginary number based on torque and acceleration. -------------------- 2001 Celica GT-S Turbo
Lo-Fi Version | Time is now: December 1st, 2024 - 6:12 PM |
