Probably a dumb question, 7AFE engines |
Feb 22, 2013 - 12:36 PM |
Enthusiast Joined Feb 13, '13 From Omaha, NE Currently Offline Reputation: 0 (0%) |
Okay so basically my 94 ST had a cracked block (that had some kind of temporary fix to it that masked anything I could see) when I bought it back in december and it blew out after about 3k miles.
So my question is regarding the 7AFE engine that is in that model. Are all the 7AFE engines the same? And I mean all of them, even between different car brands. I'm guessing the heads are probably different and I could probably salvage the ones off of my car if that is the case. Thanks Wolfo |
Feb 22, 2013 - 1:02 PM |
Enthusiast Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
I'm guessing the heads are probably different and I could probably salvage the ones off of my car if that is the case. Right direction I believe the majority of issue is with the intake manifold. Swapping over from the old solves that issue. This post has been edited by rave2n: Feb 22, 2013 - 1:03 PM |
Feb 22, 2013 - 2:11 PM |
Enthusiast Joined Sep 6, '12 From Holland Currently Offline Reputation: 1 (100%) |
The engines are the same i believe. Only the newer ones are OBDII instead of OBDI. Maybe the newer ones have EGR and the older ones not? Don't know that for sure though!
Feb 23, 2013 - 12:20 PM |
Feb 24, 2013 - 7:36 PM |
Much appreciated guys.
Lo-Fi Version | Time is now: December 3rd, 2024 - 4:41 AM |
