Enthusiast ![]() ![]() ![]() Joined Jun 5, '06 From Hayward,CA Currently Offline Reputation: 4 (100%) ![]() |
Hey guys, I lost my alarm remote a while back and ordered a new one on eBay that supposed to work with it. It says I need to press some button on the ECU to program the remote. Any help as to where I can find the ECU?? I have a 99 GT. any help would be highly appreciated thank you.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 29, '10 From Lake Havasu City, AZ Currently Offline Reputation: 31 (100%) ![]() |
Nope. You dont need the ecu..
Look under your driver seat for a black box. That box is the controller for alarm system. If I remember right there is a little green button that you press and hold for like 5 seconds. While doing so look at your dash, under the steering wheel, where the security sound sensor is, there should be a flashing red LED. before it flashes either 3 or 5 times you need to press and hold the lock button on your new remote. If its successful I believe the car locks then unlocks. Hope that helps and hope it works.. been awhile since I did mine. -------------------- ![]() 6gcHeroes:808hectortimmybatmandiegotigamak |
That worked perfectly thanks so much!!
That worked perfectly thanks so much!! No problem, glad it worked ![]() -------------------- ![]() 6gcHeroes:808hectortimmybatmandiegotigamak |
Lo-Fi Version | Time is now: February 13th, 2025 - 6:52 AM |
