> Clunking noise?
post Jan 20, 2004 - 11:34 PM
Showoff
Joined Jan 17, '04
From MA
I've got a 95 GT coupe and whenever I hit a bump small or large I get this clunking/slightly rattley noise from the rear (drivers side i think). There is nothing loose in the car the seats locked into place....Please help......
Replies (1 - 14)
post Jan 21, 2004 - 1:52 AM
macavely
Joined Nov 4, '02
do a bounce test to see if you need new struts in the back
post Jan 21, 2004 - 10:21 AM
Showoff
Joined Jan 17, '04
From MA
ok...bounce test.....do what ...and look for what while doing it?
post Jan 21, 2004 - 10:27 AM
klr_toy
Joined Feb 18, '03
From Hermiston, OR
bounce the back of the car (with your hands) and listen for the noise to see where it's coming from. If it comes from your struts. They are most likely toast.
post Jan 21, 2004 - 11:06 AM
LatinKraze
Joined Oct 22, '03
Mine does the same thing, except it does it while driving. But mine has something lose in the rear break. Might be a caliper...i think thats what its called. Only goes away when i apply on the brake.
post Jan 21, 2004 - 12:48 PM
97GTinKC
From KC
might also be just a sway-bar link...have someone else bounce it while you look for the source of the noise
post Jan 21, 2004 - 1:57 PM
Showoff
Joined Jan 17, '04
From MA
Thanks everyone but the bounce method produced nothing....no creaks, squeaks, clunks, or anything else. The noise seems to be more reactionary than if it were a strut. I thought the jack was loose in the trunk...that is as best as I can describe the noise and situations that it occurs from. It's cold out, so I may just give up and bring it to the shop. But opinions are greatly appreciated.
post Jan 21, 2004 - 2:34 PM
aaronc222
Joined Sep 22, '02
From Detroit
QUOTE (LatinKraze @ Jan 21, 2004 - 9:06 AM)
Check the caliper bolts. Both myself and a fellow 6g here in Chatt have lost caliper bolts. I don't know where to find the bolt for the rear, but for the front caliper I took another one out and brought it to Autozone where I found one that fit perfectly.
SpedToe169
From Dallas, Tx
I've had the same thing ever since I put in my ground controls. Its something suspension related but I haven't figured out what yet. I need to have somebody else drive the car so I can go back there and have a listen. I'm guessing its something with the upper strut mount.
post Jan 21, 2004 - 2:42 PM
Cormudgen
Joined Jul 31, '03
From GA
QUOTE (SpedToe169 @ Jan 21, 2004 - 12:34 PM)
i have the same noise but assumed it's the sway bar end linkage even though it does sound more so like its' comming from the top of the strut mount. have you fixed your sway bar linkages yet? also are you still selling the bearing kit for Ground Controls?
cormudgen
post Jan 21, 2004 - 9:27 PM
hyp3rk1d
Joined Sep 22, '03
same problem here... any1 find the solution to fix this yet?
post Jan 22, 2004 - 12:26 PM
Showoff
Joined Jan 17, '04
From MA
I took the car to the dealer this morning (had to get a sticker anyways, the Toyota dealer is the closest place to me to do that) had them check it out while they had the car. Rear sway bar bushings shot Adding to the problem the rear struts are on thier way out (says dealer). They want $100 to do the bushings. I'm sure you all know how much they want for new struts/mounts.
This post has been edited by Showoff: Jan 22, 2004 - 12:26 PM
post Jan 22, 2004 - 1:02 PM
SpedToe169
From Dallas, Tx
What a rip off. You can do it yourself. Its cake.
I know mine aren't bad because they're practically brand new.
I'm pretty sure its not the end links as I've checked them. This sound is definitely 'in' the chassis. It sounds like something attached directly to it.
Yeah, I'm still selling the bearing kits. I'm not sure if I'm going to keep doing it tho. Nobody has bought them and I've had mixed results with mine. They're hard to keep clean and working properly when driving on the street. They work great for several thousand miles, then they need to be cleaned and greased. Its not a big deal, but its something I doubt most people will do.
post Jan 23, 2004 - 3:20 PM
Cormudgen
Joined Jul 31, '03
From GA
QUOTE (SpedToe169 @ Jan 22, 2004 - 11:02 AM)
true, i'm way to lazy to take my suspension apart every 2-3 months.
i think i'ma get some eibachs when i redo my suspension
cormudgen
post Jan 23, 2004 - 6:52 PM
SpedToe169
From Dallas, Tx
You don't have to take the suspension apart, you just have to jack the car up and take the wheels off.
Lo-Fi Version Time is now: February 22nd, 2025 - 10:50 PM
