> Air Induction, Options?
post Mar 24, 2013 - 1:18 PM
XxDarkLightning
Joined Apr 13, '09
From MA
Hello there,
Getting near the end of my swap (or so I think but never am as you all know the case) and I have seen an array of setups for Air Intakes and BOV/BPV. I was thinking of going with the BPV as I plan to recirculate it and was curious if MR2 and GT4 are the same functionally. I see they mount differently. Also, pertaining to the two inlets I have highlighted, some owners put little individual filters on these. Are there any drawbacks when doing this or reasons why I should have them go into air intake? The lower one I believe is a controlled vacuum leak which would make sense to be connected to the air intake but I figured I would ask around anyway for both. Thanks everyone!
This post has been edited by XxDarkLightning: Mar 24, 2013 - 1:22 PM
Replies (1 - 4)
post Mar 24, 2013 - 5:56 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
the bottom hole your pointing too, hope you got the right one becuase that looks like the turbo water return port
Yeah otherwise use mini filters on them
Mike W
269awhp / 273ft-lbs
post Mar 26, 2013 - 10:28 AM
Sunny
Joined Nov 15, '10
From Austria
Hi,
- on top is the OEM oil catch can, just mount a small filter (the oil dramatically reduces the ROZ of the fuel)
- buttom, is connected to the air box and the TB or in other words thats the line the ISCV uses to get air, further more the turbo VSV and power steering pump bleed the air to it, connect this line to
a line after the air filter
greetz
KEEP COOL UNDER PRESSURE
post Mar 27, 2013 - 1:30 AM
Soulend
Joined Nov 24, '07
From Tucson, Az
QUOTE (Sunny @ Mar 26, 2013 - 8:28 AM) *
Hi,
greetz
This guy has it.
You can also just put a small filter on the bottom one as well.
Kevin
post Mar 29, 2013 - 6:22 PM
XxDarkLightning
Joined Apr 13, '09
From MA
Awesome thanks for the input everyone!
Lo-Fi Version Time is now: January 15th, 2025 - 7:57 PM
