> rim help
post Mar 24, 2013 - 11:17 PM
hzawde
Joined Nov 13, '10
From Calgary
if you dont mind going to this link http://www.nlmotoring.com/XXR-535-Wheels-s/1693.htm let me know which offset/size of rim i should get and what tires would go well with them , for my gt four . thank you !
Replies (1 - 12)
post Mar 25, 2013 - 12:05 AM
that is a decision only u can make, we cant tell u what i like, because what i like may not be what u like.
i have 16 x 8 offset 35 with 225/45/16 tires... and i like it. i went from 17 x 8 offset 45
but ull get maybe 10 different opinions right after mine.
post Mar 25, 2013 - 9:36 AM
hzawde
Joined Nov 13, '10
From Calgary
QUOTE (njccmd2002 @ Mar 25, 2013 - 1:05 AM) *
sorry maybe i wasnt clear.
I know that i want 17" i just dont know which width and tire combo would make it look somewhat flush , compare to the sucked in look
it has now
post Mar 25, 2013 - 10:48 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
http://www.6gc.net/forums/index.php?showtopic=69919
use this as a sizing guide
you will need different offsets for each axle set of wheels, as the rear is more sucked in, youll need a lower offset than you will have on the front
エキサイティングカーレーシングチーム!
post Mar 25, 2013 - 4:35 PM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
Well if your going 17" you only have 7" or 8.25".
Going the 8.25" will sit real flush, but you'll need a 15mm spacer in the rear.
Tyres is up to you, depends if you want a good sidewall or a stretched look, probably a 215/45 would be alright!
post Mar 25, 2013 - 11:56 PM
hzawde
Joined Nov 13, '10
From Calgary
QUOTE (Timmyface @ Mar 25, 2013 - 5:35 PM) *
okay thanks , what about the offsets that are available ? i think if i go 17x7 it would be +35
post Mar 28, 2013 - 7:15 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (hzawde @ Mar 25, 2013 - 9:56 PM) *
That's the only offset they have on that link for our car? Lol. Next time when I buy wheels for my car. I'm going to try to get 8j with +25 the least and +35 the most.
post Mar 29, 2013 - 1:30 PM
hzawde
Joined Nov 13, '10
From Calgary
lol no those are the choices of rims i have to choose from ,
either 17x8.25 +35
or the same but +20
which one would fit better ?
post Mar 29, 2013 - 3:01 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (hzawde @ Mar 29, 2013 - 11:30 AM) *
either 17x8.25 +35
or the same but +20
I'd say with the 8.25, the +20 for the front is going to stick a bit so you'll probably need a fender roll and pull. Also will need stretched tires. But +20 in the rear is just about perfect. If I were you, I'd stagger them and go +35 in the front and +20 in the rear. Rather have a higher offset so you can adjust the offset by buying spacers. Best to be on the safe side than spend loads of money on a wheel that doesn't fit your car. Lol.
This post has been edited by ILoveMySilly97: Mar 29, 2013 - 3:02 PM
post Mar 29, 2013 - 4:18 PM
hzawde
Joined Nov 13, '10
From Calgary
i cant stagger though , its all wheel drive
i just want something that i dont need to roll anything, just bolt on and finished , it doesnt need to be perfect flush
post Mar 31, 2013 - 5:26 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (hzawde @ Mar 29, 2013 - 2:18 PM) *
Oh. Then in that case. Just go with the +35. That offset won't be horrible looking. It'll be bareable. If you ever want to get that flush look then you can always buy spacers in the future. But if your car is going to be slammed or low then you'll need fender roll with both offsets because of the width. If you're on lowering springs then you should be fine. I don't know how stiff the stock gt4 shocks are but I remembered on my st204 with 17x8 +35 225/45/17 in the rear. It would rub on bumps. The best tire size for a 8.25j would but 215/45 or 225/45 for that perfect sidewall with no stretch. Plus it's a gt4 so why not go for the wider tire. Lol.
post Mar 31, 2013 - 12:54 PM
hzawde
Joined Nov 13, '10
From Calgary
thanks for your help man , so 8.25 +35 running 225/45 sounds like the winner , if im correct
post Mar 31, 2013 - 4:23 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (hzawde @ Mar 31, 2013 - 10:54 AM) *
No prob.
Lo-Fi Version Time is now: November 26th, 2024 - 4:48 AM
