> First celica., help needed.
post Mar 28, 2013 - 3:54 PM
vinnyhull
Joined Feb 26, '13
From Hull, UK
hey just bought my first celica and am looking for some help to get it running how i would like. the front cv joint clicks while turning so i have got myself a replacement drive shaft and am going to change it out over the weekend. the only issue is that its passenger side and all the how2s i can find seem to deal with drivers side onle. its a 1997 2.0 gt uk model with abs. any help or advice would be greatly appreciated.
cheers
Vinny
Replies (1 - 11)
post Mar 28, 2013 - 4:03 PM
Just make sure the ABS ring is present.
post Mar 28, 2013 - 4:08 PM
rave2n
Joined May 29, '09
From Gainesville, FL
Passenger side is cake. Just remove the axle bolt from the hub. Move it out of the way, then remove the 2 bolts that are in the middle of the shaft attaching to the bracket.
Slides right out of the trans.
Edit: make sure you drain the trans first!
This post has been edited by rave2n: Mar 28, 2013 - 4:09 PM
post Mar 28, 2013 - 4:16 PM
vinnyhull
Joined Feb 26, '13
From Hull, UK
cheers. abs ring is there and ready to go in. its just that ive seen a couple of how2s and they say to strip everything down completely.
post Mar 28, 2013 - 5:33 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE (rave2n @ Mar 28, 2013 - 4:08 PM) *
His is RH drive probably since he's from the UK.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Mar 28, 2013 - 6:06 PM
rave2n
Joined May 29, '09
QUOTE (DEATH @ Mar 28, 2013 - 5:33 PM) *
Hah good point! - Pry away, or slide hammer with fork.
post Mar 28, 2013 - 7:32 PM
vinnyhull
Joined Feb 26, '13
From Hull, UK
im guessing that means there is a difference in how they come out of the transmission, depending on what side of the car its on?
post Mar 29, 2013 - 6:34 AM
rave2n
Joined May 29, '09
QUOTE (vinnyhull @ Mar 28, 2013 - 7:32 PM) *
Yessir.
The short shaft has a c-clip on the end, and requires prying out, or using a slide hammer with a fork on it. The longer shaft is simply held in place with a bracket in the middle, and just slides in and out the trannie without a clip.
Either way, both sides you are going to disconnect them from the wheel assembly via the axle nut. I remove the strut bolts so I have more room to move the hub around. Once you remove the bottom end from the wheel assemblies you just go at depending on which you are working on.
The one with the clip can occasionally be a pain, if it takes you more then 30 minutes prying to get it out, I would go find a slide hammer.
This post has been edited by rave2n: Mar 29, 2013 - 6:35 AM
post Mar 29, 2013 - 9:04 AM
Malek
Joined Jan 26, '09
From Los Angeles
QUOTE (rave2n @ Mar 29, 2013 - 7:34 AM) *
Yessir.
[size="4"][/size]
Don't even waste your time trying to pry it out! If you can go rent a slide hammer (maybe not in the UK..?) then do that and take 5 seconds to pull the axle out! I wasted idk how much time fking with it until I drove myself to Advanced Auto and rented a slide hammer with a hook attachment. First slide of the hammer and it popped out. I was a little upset at myself for wasting so much time..
post Mar 29, 2013 - 11:22 PM
rave2n
Joined May 29, '09
QUOTE (Malek @ Mar 29, 2013 - 9:04 AM) *
Feel ya.
I've pulled that axle 5 times now, the first 2 times easy...next 3. I was screaming so loud the area thought I was crazy. Rent the slide hammer, 15 seconds its out. Truly though, I've noticed if the axle doesn't have any play when into the trannie, it comes out easy with a few taps and a pry bar. Possibly a bearing going bad, or just old age..no idea, but it appears on the abused transmission it takes alot of work to get that beast out.
post Mar 30, 2013 - 2:28 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Just get underneath and using something flat lean it against the cv axle going into the transmission and tap on it outwards then rotate axle, tap again, rotate, tap again until it comes out and then pull it off. Super easy and doesn't even require a slide hammer.
post Apr 4, 2013 - 2:24 AM
vinnyhull
Joined Feb 26, '13
From Hull, UK
done it cheers guys. was the short side axle. left the entire hub assembly together it just moved out of the way. gave the shaft a good old tug and the inside joint collapsed. blessing in disguise realy as i had loads of room to stick a prybar in each side and it popped out no worries.
Lo-Fi Version Time is now: November 23rd, 2024 - 3:23 PM
