> boost gauge help, aem digital gauge
post Mar 30, 2013 - 8:02 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
i have a 2nd gen 3sgte swapped in a 1995 celica. i installed an aem digital boost gauge. i have the gauge grounded properly an the positive side is connected to the radio fuse. i tried tapping into to locations to get a vacuum reading. first the map sensor line and second on the timing belt side of the the engine, on the intake manifold. i get wrong readings in both cases. i check the aem pressure sensor and everything checks out fine. any suggestion, or wisdom is greatly appreciated.
Replies (1 - 19)
post Mar 30, 2013 - 8:21 PM
Syaoran
Joined Jan 4, '12
From US
Use any nipple from the intake manifold. What do you mean wrong readings? What are you comparing it to?
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Mar 30, 2013 - 8:24 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
it reads 22 psi at idle... not 22 inhg. im thinking it is a constant voltage issue? the gauge calibrates itself each time the key is clicked.
post Mar 30, 2013 - 9:42 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (garin @ Mar 30, 2013 - 9:24 PM) *
It's an electronic boost gauge? (I mean with the sender?) That's why I like the mechanical ones, it's probably a faulty sender or a bad connection somewhere. Check them pesky grounds.
post Mar 30, 2013 - 9:47 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
i suppose that is good advice. only got this one to match my aem wideband.
post Mar 30, 2013 - 10:35 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
still no luck when the car is on, but not running it reads 35 on the sweeping light display and 0 on the digital display. when the car is on it reads 22psi at idle...
post Mar 30, 2013 - 10:39 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (garin @ Mar 30, 2013 - 3:02 PM) *
you shouldn't tap into the map sensor line. The map sensor needs a dedicated vacuum source to output the correct voltage to the ecu based off of the pressure. Most things that connect to vacuum will have a pressure sensing disk thing or shifting diaphragm that will change the vacuum/boost on the map sensor(or boost gauge), and thus change the voltage reading that the map sensor outputs based off the vacuum/boost. I'm not saying that this is the culprit for your incorrect readings on your boost gauge, but it does need a dedicated line to get the most accurate reading.
This post has been edited by match220: Mar 30, 2013 - 10:49 PM
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Mar 30, 2013 - 10:49 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
yea i switched it to the other side of the intake manifold.
post Mar 30, 2013 - 11:04 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (garin @ Mar 30, 2013 - 5:49 PM) *
in theory, the center of the intake manifold is supposed to output the most correct reading since it is equally affected by all cylinders, I don't have a way to test that, but it makes sense. I have my map running off the side because I'm about 1 foot short of hose, but I plan on moving it to the center. I believe the 5sfe had the map sensor hose going into the manifold close to the center, and I found a nipple on the center-bottom-rear of my gen3 3sgte manifold that was the same size of the map sensor manifold port...since I bought the engine in parts I don't know what went there though. Since the boost gauge is just for looking at and not for the computer to read I would put it on it's own vac source near center.
You could always drill and tap a 1/8 npt threaded hole and put a new nipple on, just connect an air compressor line to an open vac port and have a friend blow puffs of air out every couple seconds so you don't get aluminum in the engine. smile.gif
This post has been edited by match220: Mar 30, 2013 - 11:08 PM
-Jay
post Mar 30, 2013 - 11:12 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
but would that cause the gauge to read 22psi at idle?
post Mar 30, 2013 - 11:24 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (garin @ Mar 30, 2013 - 6:12 PM) *
are you sure it's psi and not kpa? my car is 33 kpa at idle according the the autronic display. If your aem boost gauge is like my aem wideband gauge (which I want to sell if anyone is interested) it has a selector switch on the back where you can change the output to the gauge display or to the aftermarket ecu that you are running
-Jay
post Mar 31, 2013 - 8:10 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
there is no selector switch on the back.
i figured it out. i used the ignition fuse for power. i just uninstalled everything and rewired it. everything works now. power has to be constant, because the gauge calibrates itself at each key turn. not sure if im s fan of these gauges.
This post has been edited by garin: Mar 31, 2013 - 8:18 AM
post Mar 31, 2013 - 6:44 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (garin @ Mar 31, 2013 - 3:10 AM) *
My aem wideband controller/gauge is the same way. I had it wired to a ignition switched power source and it takes a couple seconds to come on before it shows the a/f ratio, so now I turn it on before I turn the car on. I like certain things about it, but I have my eye on another one that has signal and signal ground output wires for aftermarket ecus. The output of mine is inaccurate without the signal ground.
-Jay
post Apr 1, 2013 - 6:06 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
these gauges seem to be nice, but quirky at the same time.
post Apr 1, 2013 - 6:40 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (garin @ Apr 1, 2013 - 1:06 PM) *
yeah, I like the look. But as a high quality wideband meter it sucks. I never thought of AEM being incredible, just something that gets the job done, their aftermarket ecus have a lot of dumb tuning flaws but can still be worked with by AEM tuners that know how to work with them. The wideband meter has a signal out, but since it doesn't have a signal ground output then aftermarket ecus cannot accurately determine the voltage output of the sensor. The more expensive wideband controllers output a signal positive and a signal negative. It isn't a big deal on the gauge, the gauge displays an accurate reading since it reads a positive and negative signal from the wideband sensor, and the data log output will be accurate, but the signal output to the ecu is wrong. My autronic reading is always +/- 1 on the air/fuel gauge depending on whether or not I have the headlights on. Also, since i'm running individual coils on my engine, they will pull more electricity at higher rpms, further affecting my air/fuel ratio by changing the overall voltage. It is irritating that the AEM wideband controller is made so crappily. It seems that the signal output is only a selling point and not really a fully functional unit. Again it works great when not feeding my autronic, but sucks on a car that requires accuracy.
I would imagine that the boost gauge is made with the same "love and care" and has flaws of its own.
-Jay
post Apr 2, 2013 - 12:03 PM
QUOTE (garin @ Apr 1, 2013 - 7:06 PM) *
post Apr 3, 2013 - 8:41 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
QUOTE (lagos @ Apr 2, 2013 - 1:03 PM) *
the instructions sucked lol.
post Apr 3, 2013 - 9:00 AM
for future reference, almost all digital/electrical gauges need to be on a constant 12V source. something that does not get turned off when you turn the key to start.
post Apr 3, 2013 - 9:27 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
i know. i powered it to to radio fuse... didn't work, so i went off of the ignition.
post Apr 15, 2013 - 3:04 AM
chrismru
Joined Apr 15, '13
From Mauritius
Hello friends...Hey any1 can help me on an st205 stock engine...Where should i connect my boost gauge vaccum line on the inlet manifold?????, i'm not using charcoal canister ..any1 plz? send me some pics or explain briefly plz smile.gif
This post has been edited by chrismru: Apr 16, 2013 - 1:23 AM
Lo-Fi Version Time is now: December 2nd, 2024 - 12:39 PM
