> mounting the cruise control actuator elsewhere?
post Mar 30, 2013 - 10:46 PM
match220
Joined May 13, '06
From Kaimuki, HI
Has anyone else considered mounting the cruise control actuator somewhere else? Below is what I have to work with..haha. I thought about cutting a hole in my custom airbox and mounting it sideways in there. Other than that I have that big gap area around the distributor and behind the intake piping, but I would need a shorter cable running to it from the firewall. What do you guys think?
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
Replies (1 - 17)
post Mar 30, 2013 - 11:07 PM
Malek
Joined Jan 26, '09
From Los Angeles
Haha let me know if you figure something out because I just got rid of my actuator for my swap..
post Mar 30, 2013 - 11:13 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (Malek @ Mar 30, 2013 - 6:07 PM) *
roger...
it's smaller than it seems once it's taken off of the metal mount that went under the battery tray. It's small enough for me to mount to the top of my turbo intake pipe, but I didn't want weight sitting on it and I couldn't get it to mount sturdily on a round pipe.
-Jay
post Mar 30, 2013 - 11:35 PM
you could mount it on the passenger side like the ST has it. just extend the wiring
post Mar 30, 2013 - 11:47 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (Smaay @ Mar 30, 2013 - 6:35 PM) *
Oh yeah, there is a nice little gap over there between the coolant filler neck and the power steering reservoir. Anyone have pics of the 7a setup? I would also need the cruise control cable from the 7a ST though wouldn't I?
-Jay
post Mar 31, 2013 - 6:09 AM
you can mount it pretty much anywhere the cable will reach without kinking.
post Mar 31, 2013 - 6:51 AM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (match220 @ Mar 30, 2013 - 11:47 PM) *
That gap is for the ABS, but does provide some room for you.
The cruise control on a ST is located where the Power Steering Res is located. Shown below.
Would be an interesting mounting, but I'm sure feasible!
post Mar 31, 2013 - 6:40 PM
match220
Joined May 13, '06
From Kaimuki, HI
I am most definitely doing it, I'll just need to buy the cruise cable for a 7a celica and run it over to that side. The cruise cable for the 5s definitely won't reach. I don't have ABS so I have plenty of space for it.
-Jay
post Apr 1, 2013 - 6:43 AM
bsamps4
Joined May 16, '10
From Raleigh
I re-mounted mine. Made a custom bracket for it. You can see it here in this picture. It's above the air filter, and to the right of the
blow off valve.
post Apr 1, 2013 - 10:16 AM
^^^^ dang its crowded in there
post Apr 1, 2013 - 12:12 PM
rave2n
Joined May 29, '09
QUOTE (Smaay @ Apr 1, 2013 - 11:16 AM) *
Crowded with POWER!
post Apr 1, 2013 - 3:18 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (rave2n @ Apr 1, 2013 - 7:12 AM) *
Crowded with POWER!
haha..at both of you. Yes that is very crowded.
Unfortunately I made a battery mount there, as you can see in the side of my picture above. You mounted yours in the trunk I imagine?
-Jay
post Apr 4, 2013 - 12:16 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
I relocated mine near the clutch master. Although there is very little clearance, it doesn't touch or rub on anything there. Uses the original GT cruise control cable. Only downside is not being able to run the plastic cover with it. I've had it like this for a few years now, and works great. No trouble with cable kinking at all.
post Apr 4, 2013 - 12:28 AM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (MaskedMan @ Apr 3, 2013 - 7:16 PM) *
that is an awesome place for it!! but I have an alarm horn there. I'm glad it fits, I can easily move the alarm horn somewhere else and put my cruise control there though. My cable will kink for sure, it has a bad spot in it that may make it kink.
Is the wiring easily accessible from there to shorten it? Or does it run through the main loom to the passenger side?
-Jay
post Apr 4, 2013 - 12:44 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
QUOTE (match220 @ Apr 3, 2013 - 10:28 PM) *
Hmm, it's been awhile, but I'm pretty sure the factory cruise control wiring is run down the driver side, so it should be very simple to get the wiring where you need it to be.
post Apr 4, 2013 - 6:44 AM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (MaskedMan @ Apr 3, 2013 - 7:44 PM) *
yeah, my first thought was to extend the wires, but if they are running that way it would be easier to just tap into them back there. I think there is a bundle of wires with a yellow wire channel around them on that side. I'll look tomorrow.
-Jay
post Apr 30, 2013 - 10:05 PM
toyotatech3
Joined Jul 30, '04
From colorado
heres mine. its not mounted yet but thats about where its going.
post May 1, 2013 - 12:14 AM
schmooot
Joined Sep 29, '09
From Prince George, BC CANADA EH!
ST205 Crew represent
Challenge Accepted
Lo-Fi Version Time is now: November 29th, 2024 - 4:03 AM
