steering, serios stearing issue |
Apr 20, 2013 - 2:14 AM |
Enthusiast Joined May 20, '12 From motown,wv Currently Offline Reputation: 0 (0%) |
When driving the celica at any speeds aspecially at higher speeds the entire car shakes and the steering wheel shakes irradically.
Apr 20, 2013 - 4:18 AM |
Enthusiast Joined Jun 2, '10 From Davenport, Florida Currently Offline Reputation: 0 (0%) |
When driving the celica at any speeds aspecially at higher speeds the entire car shakes and the steering wheel shakes irradically. check your front tires for a "bubble" on the road surface of the tire. if some of the steel belts inside one of the tires snapped it will produce a bubble in the tire that will cause extreme vibration while driving, the faster you go the more the car will shake -------------------- |
Apr 29, 2013 - 3:14 PM |
Enthusiast Joined Oct 5, '12 From Los Angeles, CA Currently Offline Reputation: 0 (0%) |
Had this same problem a month ago so I took it to the shop. My front tires were wearing off irregularly from the inside which I couldn't see. Changed the front two tires and it fixed the problem.
Apr 29, 2013 - 5:26 PM |
Enthusiast Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
Have your tires balanced and have the alignment checked. Just did mine yesterday cause steering wheel is shaking intermittently on highway speeds. Turns out that the wheel is off balance but the alignment is good.
-------------------- God made man....
Everything else... Made in China |
Lo-Fi Version | Time is now: December 1st, 2024 - 1:33 PM |
