![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 5, '09 From West Texas, USA Currently Offline Reputation: 20 (100%) ![]() |
I'm having trouble locating my ecu. Where exactly is it at?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) ![]() |
If you go in throught the passenger side, its located behind the dash on the floor, fairly close to the firewall. Its diretly in line with the shifter.
I know this a farily poor description but If you crawl down and take a look, its pretty easy too see. IIRC you don't have to pull any carpet back, just gotta stick your head there ![]() Hopefully this helps a bit. This post has been edited by jordisonjr: Apr 22, 2013 - 1:06 PM -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
If you go in throught the passenger side, its located behind the dash on the floor, fairly close to the firewall. Its diretly in line with the shifter. I know this a farily poor description but If you crawl down and take a look, its pretty easy too see. IIRC you don't have to pull any carpet back, just gotta stick your head there ![]() Hopefully this helps a bit. Thanks I found it. -------------------- |
Lo-Fi Version | Time is now: February 22nd, 2025 - 12:38 AM |
