> My Celica, with BEAMS
post May 7, 2013 - 9:26 PM
aspen
Joined Nov 29, '07
From Colorado
So here's my Celica as she stands now:
And when I got her, nearly 6 years ago at 139,000 miles:
She's a 1994 GT. Fully stock when I bought it(wheels aside). Perfectly clean. Never been in an accident.
Now it's got whited out JDM Tails, ST Suspensions sway bars, new Konig wheels and Megan Racing coilovers.
A few weeks ago I started getting some possible signs of a broken head gasket. So, I decided to dive in and do something that I've been wanting to do for a while.
So, today I got:
Gaskets are on their way. I've already got a new clutch and some motor mounts. New cluster is on it's way too. Just setting to work on electrical until then!
2019 M2, 2005 S2000, 1997 4Runne
Replies (1 - 19)
post May 8, 2013 - 2:35 AM
JoshuaM
Joined Mar 6, '12
From Brisbane, Australia
woot.gif BEAMS AWESOMENESS!!!!
post May 8, 2013 - 5:42 AM
richee3
Joined Jun 29, '08
From Denver
Will you be extending the harness or going through the firewall? Good luck. smile.gif
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post May 8, 2013 - 8:50 AM
aspen
Joined Nov 29, '07
From Colorado
I'm planning on extending the harness the 40 some inches! Don't really want to have a hole in the firewall to plug.
post May 8, 2013 - 9:15 AM
richee3
Joined Jun 29, '08
From Denver
I extended mine 24" which was still a little too much.
1998 Celica GT-
BEAMS Swapped.
post May 8, 2013 - 9:33 AM
aspen
Joined Nov 29, '07
From Colorado
So you'd do closer to 20"? And it's just on the section between the firewall and the first plug (MAF)?
I may pick up a second 5S-FE harness later today, and use that as an idea for length for everything (and probably steal wires from it too).
post May 8, 2013 - 12:44 PM
Malek
Joined Jan 26, '09
From Los Angeles
I put a hole in my firewall tongue.gif haha
post May 8, 2013 - 2:01 PM
richee3
Joined Jun 29, '08
From Denver
20-24" is good. Like I said, mine was a little long but I'd rather have it a little too long than a little too short. I extended mine between the MAF and firewall. It wasn't too complicated. Time consuming, yes, but not difficult. Now is definitely the easiest time to extend it, I'm tired of swapping harnesses in the engine bay laugh.gif Picking up a spare 5S harness is a good idea. If its OBDI, it may not have all the same color wires as the BEAMS harness.
This post has been edited by richee3: May 8, 2013 - 2:01 PM
1998 Celica GT-
BEAMS Swapped.
post May 8, 2013 - 6:04 PM
aspen
Joined Nov 29, '07
From Colorado
Good deal. I'll start on it this weekend after I finish labeling the BEAMS harness and getting it off.
Just picked up a 5S harness, it's OBD1. Some color wires are better than none. I just want to try to have as little generic white/black/blue/yellow in the harness as possible, though hopefully I shouldn't have to take it apart again for a long, long time.
post May 8, 2013 - 7:38 PM
aspen
Joined Nov 29, '07
From Colorado
First take at 3D Printing extra BEAMS logos:
post May 14, 2013 - 5:51 PM
aspen
Joined Nov 29, '07
From Colorado
Started work on the wire harness:
Got my gauge clusters in today:
And realized I got a brake upgrade with my engine. I bought a front subframe, so it has the superstrut suspension and the two pot brake calipers! Now to figure out what rotors I need for them.
Still waiting on the gaskets and timing. At this point, that's all I need to take out the 5S and put in the BEAMS!
post May 15, 2013 - 4:47 AM
S8S8
Joined May 9, '09
post May 19, 2013 - 9:11 AM
aspen
Joined Nov 29, '07
From Colorado
Worked yesterday to free the new engine from the front subframe and...success!
post May 24, 2013 - 11:59 AM
Syaoran
Joined Jan 4, '12
From US
I like that white faced cluster. What is it from?
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post May 29, 2013 - 6:22 PM
aspen
Joined Nov 29, '07
From Colorado
Those are the gauges from an SS-III.
Also, got the old 5S-FE dyno'd today as a base mark. Not as tired of an old girl as I thought she was:
5S-FE @ 5200 feet elevation.
Short ram intake.
91 Octane.
post May 29, 2013 - 7:06 PM
Box
Joined Feb 23, '12
From Warrior, AL
Good job so far, and good luck on your swap. Finally your Celica will be the car it should've been all this time. Why Toyota ruined the USDM Celica with a Corolla or Camry engine I'll never know.
2001 Miata LS 5-speed
post May 29, 2013 - 7:47 PM
ricochet1490
Joined May 3, '11
From Ohio
I have super strut everything in the front. 5s regular rotors are what you want if you use everything.
post Jun 13, 2013 - 10:17 PM
aspen
Joined Nov 29, '07
From Colorado
Been working on the head and block. Unfortunately my time table is set back a bit as I think I'm going to get the head and block machined. There's just too many pits and such of questionable size. Do it once, do it right.
Some pictures though:
This post has been edited by aspen: Jun 13, 2013 - 10:18 PM
post Jun 23, 2013 - 7:46 PM
aspen
Joined Nov 29, '07
From Colorado
The BEAMS is in. And Runs. (Started on the first try!!!).
Pictures forthcoming. Thanks to everyone's help, and most especially richee!
post Jun 23, 2013 - 8:15 PM
richee3
Joined Jun 29, '08
From Denver
No problem, glad to help out and glad to hear your BEAMS started on the first try!
This post has been edited by richee3: Jun 23, 2013 - 8:15 PM
1998 Celica GT-
BEAMS Swapped.
Lo-Fi Version Time is now: November 22nd, 2024 - 7:10 AM
