two clutch switches? |
May 17, 2013 - 4:50 PM |
Enthusiast Joined May 13, '06 From Kaimuki, HI Currently Offline Reputation: 10 (100%) |
Does anyone know why the Celica has two clutch switches? I found the little plastic button/stopper on the floor of my celica today (the one that the brake or clutch switch presses against). I thought it was the one from the brake light switch but my brake lights aren't stuck on, and when I checked the brake button was in the bracket. I looked around and saw the two clutch switches. One is on a bracket mounted exactly as the brake switch is mounted, the other is on the floor and is depressed when the clutch is on the floor. The car starts fine with the clutch pressed, then I tried starting the car without pressing the clutch, it didn't start, so the floor clutch switch is the one for the starter circuit. I checked the wiring diagrams in both the Haynes and Chiltons manuals, neither one shows a second clutch switch. I'm guessing it might be part of the cruise control system, so if you start to press the clutch the cruise control will shut off. Unfortunately I have disconnected my cruise control so I can't test to see if that is what it is. Mine is a convertible model, but I doubt it has anything to do with the convertible system.
-------------------- -Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other 01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished 02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve |
May 17, 2013 - 6:24 PM |
Enthusiast Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
More than likely a cruise control switch.
May 17, 2013 - 6:49 PM |
More than likely a cruise control switch. That. As you push the clutch in with cruise on the cruise automatically deactivates. -------------------- 2001 Miata LS 5-speed
May 17, 2013 - 7:20 PM |
More than likely a cruise control switch. That. As you push the clutch in with cruise on the cruise automatically deactivates. cool, thank you both..you have effectively satisfied my curiousity. -------------------- -Jay
Lo-Fi Version | Time is now: December 3rd, 2024 - 12:58 AM |
