> blow off valve
post Jul 6, 2013 - 3:03 AM
Bram
Joined May 20, '13
From belgium
hello,
i have a 95 celica GT FOUR and yesterday i found an old intake i had lying around.
the intake fitted directly onto my stock intake hose. the only problem is that i can not longer connect my blow off valve
is it possible to keep the stock BOV and use the intake?
Bram
Replies (1 - 5)
post Jul 6, 2013 - 11:21 AM
Yes. You can just leave it disconnected and vent the charged air to the atmosphere. Some people put a little air filter on them too.
post Jul 6, 2013 - 12:15 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (lagos @ Jul 6, 2013 - 12:21 PM) *
I think he means can the stock BOV fit onto the aftermarket piping
post Jul 6, 2013 - 12:56 PM
QUOTE (mkernz22 @ Jul 6, 2013 - 1:15 PM) *
Since he said there was no port/flange on the intake to connect it to, he can just leave it disconnected and venting. It will still function normally not being connected to the intake.
post Jul 6, 2013 - 1:14 PM
Bram
Joined May 20, '13
From belgium
QUOTE (lagos @ Jul 6, 2013 - 12:56 PM) *
i put the hose that goes to the intake in the blow off valve and started the engine, when i disconnect it, the car stops running
the hose doesn't fit properly so i cant just leave it like that
also i think toyota vented the air to a seperate room in the air filter for a reason cause otherwise they would have just connected it straigt to the intake right? or wont it make any difference if i just connect them without the air box?
post Jul 6, 2013 - 3:03 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (lagos @ Jul 6, 2013 - 1:56 PM) *
No, as in the BOV, as a whole piece, will not mount onto the aftermarket piping. He's not talking about it venting to the atmosphere. He needs to know if the stock bov will bolt onto the aftermarket piping
Lo-Fi Version Time is now: February 18th, 2025 - 2:01 PM
