> 3s-fe swap, compatibility
post Jul 9, 2013 - 10:46 PM
dominoslave
Joined Mar 25, '13
From Eagan, MN
Was looking into dropping one of these into my car in the near future to replace my ageing 5s. From what I've read, it's just a 2.0 ltr version of the 5sfe. Does anyone know if common replacement parts like the water pump, seals, gaskets etc are the same?
Replies (1 - 14)
post Jul 9, 2013 - 11:10 PM
Syaoran
Joined Jan 4, '12
From US
Yes. For the most part the engine is the same. The major change for both is in the internals of the engine, mainly smaller bore pistons and a shorter stroke.
To directly answer your question, your water inlets/outlets should stay in the same location, the intake manifold, throttle body locations should stay the same, the water pump and oil pumps are the same, and I believe that most seals and gaskets don't change.
However I'd make sure everything is compatible with the 3S-FE when purchasing your parts.
Why not replace it with a newer 5S-FE?
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Jul 10, 2013 - 3:34 AM
or a beams or a v6... dont go backwards, youll regret it. I cant remember who it was that had trouble with a 3s....
post Jul 10, 2013 - 1:56 PM
dominoslave
Joined Mar 25, '13
From Eagan, MN
Was looking into it mainly due to it being a budget friendly option. My celica is a daily driver right now that's used for delivery. I can get a 3sfe shipped to my door for about $700, any low millage 5s engines I've seen are $1k and up plus shipping. Ideally I'd like a beams, I just don't know how long my current engine will last(leaks a qt of oil per tank of fuel Amongst a few other small issues) and allow me to save up.
post Jul 10, 2013 - 2:28 PM
mkernz22
Joined May 10, '10
From MA
Don't do the 3sfe, its a lot slower than the 5sfe. Is your engine on its way out or is it just getting up there in mileage? Mines at 251k and still going strong!
post Jul 10, 2013 - 2:50 PM
dominoslave
Joined Mar 25, '13
From Eagan, MN
My car has 205k. Pulls strong, just has a tick in the top end if I'm not running 10w40, has a high pitch whine from the timing area,and leaks from the crankshaft seal. Going to be replacing the seals, water pump, and timing belt/tensioner soon. Just worried something else will fail.
post Jul 10, 2013 - 3:38 PM
6G96GT
Joined Jan 20, '08
From East Coast
I think I would go for a 3sge swap instead. There's plenty of guys here who have done it and their threads are like working manuals. I've been in a celica with a 3sge swap (the red one) and it was pretty powerful. Definitely a great power increase over the 5sfe.
post Jul 11, 2013 - 2:42 AM
PolliS_5S-FE
Joined Aug 29, '08
From Auckland, New Zealand
for the price you would pay for the motor and fitting, replacing parts etc, why don't you just buy a run about for the time being? I mean, you said its only being used for a delivery car, meanwhile if you are a fan of the Celica, save up for an upgrade (3sge) or direct replacement 5s motor?
post Jul 11, 2013 - 4:49 AM
richee3
Joined Jun 29, '08
From Denver
Sounds like all of your problems would be fixed if you replace the timing belt and all the accessories that go along with it. Replacing the crank seal wouldn't be a big deal at all while you had that side of the motor apart.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jul 11, 2013 - 7:45 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Doesn't sound like you need a new motor
Sounds like your celica is just due for a good tune up an a couple gas kits replaced
That'll be a lot cheap than a new motor
94 st hatch my daily driver
n
post Jul 11, 2013 - 8:57 PM
oil pump seal is what's pissing oil so badly.
post Jul 12, 2013 - 12:13 AM
i dont think there is a seal on the oil pump. its FIPG in place
post Jul 12, 2013 - 7:17 AM
post Jul 13, 2013 - 1:36 AM
Syaoran
Joined Jan 4, '12
From US
Oil pump's got a seal under the pump gear, and it's also got a gasket (either paper gasket or the oem plastic-y composite)
post Jul 14, 2013 - 3:55 PM
dominoslave
Joined Mar 25, '13
From Eagan, MN
Thanks for the advice guys. With the feedback I've gathered, I'll be setting some time aside in the near future to do an overhaul on all the parts in the timing area. I'll probably also do a compression test, and pop the valve cover and oil pan off at the same time to do an inspection/general cleaning. What is an acceptable range for each cylinder when i go to test them? Also, I should note that although I'm using the car for delivery right now, I'd rather not be. My other car took a crap and this was supposed to be a project car.
Lo-Fi Version Time is now: November 25th, 2024 - 8:30 PM
