Making noise |
Making noise |
Jul 31, 2013 - 12:12 AM |
Enthusiast Joined Jul 8, '13 From Norway Currently Offline Reputation: 0 (0%) |
I just did a small pull in first, hit 7k rpm, jacked it in 2nd and suddenly I hear this weird noise that goes in pace with the rpm. The higher the rpm the louder it gets. I didn't see anything extraordinary under the hood, so I'm really not sure what it can be... Transmission? Clutch? What?
Hoping for quick responses from those who got some tips. -Simon -------------------- |
Jul 31, 2013 - 1:09 AM |
Well you see, your first problem is when you went 1k over the REDLINE. Does the sound happen with the car in neutral with it being revved?
Jul 31, 2013 - 1:26 AM |
Well you see, your first problem is when you went 1k over the REDLINE. Does the sound happen with the car in neutral with it being revved? My redline starts at 7k (3SGE powered <3) But I hear the sound on both neutral/idle and when revving This post has been edited by HistoriCo: Jul 31, 2013 - 1:27 AM -------------------- |
Jul 31, 2013 - 1:36 AM |
Ahh ok, I see ST202 and immediately think our GT with the 5S. So sorry for that one. Being you hear it in neutral as well that means it's something in the engine... Also since it's in time with the rpm you're probably looking at something in the valve-train or rotating assembly. Is the sound a higher pitched ticking, or lower pitched thudding?
Jul 31, 2013 - 2:21 AM |
Here is a quick vid I just shot. You can hear the "clicking" noise in the background. Best example at the very last seconds of the video
http://www.youtube.com/watch?v=EwrcCAvwsXM...eature=youtu.be This post has been edited by HistoriCo: Jul 31, 2013 - 2:23 AM -------------------- |
Jul 31, 2013 - 2:47 AM |
Sounds like valve-train noise to me. Almost reminds me of when my 3000GT ended up with a stuck lifters/valves. It blew all of the oil out the back of it and starved the top of the motor. Have you checked the oil since? Odds are the oil level got low, that or perhaps the oil pump gave out and starved the top of the motor.
Watched it a second time and I see that your oil light is on, that's probably exactly what happened... This post has been edited by Box: Jul 31, 2013 - 2:48 AM -------------------- 2001 Miata LS 5-speed
Jul 31, 2013 - 2:52 AM |
Haven't checked the oil after it happened. But the oil lamp has always been on Checking it every week but never goes down It came on after my last oil switch
Jul 31, 2013 - 2:57 AM |
It's not an oil level light, it's an oil pressure light. Which means insufficient oil pressure, which means bad oil pump, which means trashed valve-train...
Jul 31, 2013 - 10:14 AM |
Just talked to a friend og mine and he is close to 100% certain that it is one of the valves that is pretty much dead.
When we fired up the engine to hear, I revved it a little and the sound is soooo much worse now. Hoping to have it fixed soon, but I am short on cash now that I am going on vacation for a week and just resently paid for SS-III splitters, side skirts and paint. -------------------- |
Jul 31, 2013 - 9:35 PM |
That's what I was afraid of. Just don't forget to replace the oil pump in the middle of all of it so it doesn't happen again.
Aug 1, 2013 - 1:17 AM |
Man... I can see them money flyin'!
Aug 1, 2013 - 1:34 AM |
If you find a good machine shop and do the rest of the work yourself it shouldn't be too terribly expensive.
Aug 1, 2013 - 3:32 PM |
Lol oil light redline to 7000... dude... lol you ****ed it. u need to buy a new engine now haha oil light haha
-------------------- Mike W
Aug 1, 2013 - 3:49 PM |
From what can be told from the video he only trashed the valve-train, as all of the oil would've been in the crankcase at the time it happened anyhow. Should be able to rebuild/replace the head and oil pump and be ok.
Lo-Fi Version | Time is now: December 2nd, 2024 - 1:53 AM |
