3S-GE to 3S-GE Beams |
Aug 3, 2013 - 12:06 AM |
Enthusiast Joined Jul 8, '13 From Norway Currently Offline Reputation: 0 (0%) |
As some of you may have seen, I got into some issues with my valve-train, oil pump etc. Read here
I'm now thinking what I have been craving about for a pretty long time now. I found this 3S-GE Beams engine for a fair price, but is the swap bolt-on with no major modifications? -------------------- |
Aug 3, 2013 - 5:11 PM |
Anybody?
Aug 3, 2013 - 5:47 PM |
Enthusiast Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) |
Major modifications? Shouldn't be if you have a 3s already. You'll probably need some wiring work.
-------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Aug 4, 2013 - 11:08 AM |
I would think so too... Hope I dont run into very big issues with the swap
Aug 4, 2013 - 9:02 PM |
Enthusiast Joined Nov 13, '10 From Greenville, SC Currently Offline Reputation: 50 (100%) |
I'm assuming that you're getting the ecu and such, right? The headers are different, and I believe the b-pipes are different, too. Should work with whatever clutch/transmission you've got. Different intake. Same mounts as the 5s.
Aug 4, 2013 - 9:09 PM |
The B pipe has a different mounting point for the O2 sensor but can be made to work with a BEAMS. Mounting and everything else is the same. Wiring should be pretty similar between the 3rd and 4th gens, but might need very minor changes.
Lo-Fi Version | Time is now: December 1st, 2024 - 11:23 PM |
