> HID Headlight Issue, When should I turn my lights on?
post Aug 15, 2013 - 9:07 AM
Keiri
Joined Mar 6, '04
From Charlotte, NC
Ok, so before installing HIDs and projectors I always left my low beam headlights set to "Auto/On" on the control stalk so that when you start the car the lights come on with it - I do this because it's easy to not have to worry about having them on when it randomly rains during a drive and I'm lazy enough to not want to remember to turn them on.
Now to the problem: when I changed to HIDs this weekend, I left the control stalk to "auto/on" so when the car comes on so do the lights. Unfortunately, only one HID fires on at start-up like this. I have checked my wiring and switch harnesses and the issue persists on the passenger side. I switched the ballasts and the "bad" one doesn't fire at startup when the light switch is at auto/on no matter the side but works if I start the car with the lights off. Looking into the issue, I've read that you should only turn on the HIDs after the car is started/on not auto-on.
My question: How do you guys operate your lights; do you A) have them auto/on and both HIDs fire upon start or B) start the car and then turn on your lights?
I'd like to get some answers from owners before I just assume I have a single bad ballast and return it to DDM Tuning.
Has no more Celicas
Replies (1 - 5)
post Aug 15, 2013 - 9:10 AM
bsamps4
Joined May 16, '10
From Raleigh
I leave them off and then turn them on when I need them. The way around this is to get the capacitor set up and install it with the hid's. It's just easier to flick them on when the car is running.
post Aug 15, 2013 - 9:23 AM
Keiri
Joined Mar 6, '04
From Charlotte, NC
QUOTE (bsamps4 @ Aug 15, 2013 - 10:10 AM) *
Thanks for the feedback, Ben. I'll keep the capacitor in mind - it may be my next upgrade and a good piece prior to getting an amp and sub. thumbsup.gif
Has no more Celicas
post Aug 15, 2013 - 9:24 AM
The_enD
Joined Apr 12, '13
From Bulgaria
Sounds like a bad ballast to me.
FS thread : Custom Celica parts made to order + more
Click the image to visit my FB page
post Aug 15, 2013 - 12:07 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Safest route would be to make sure you turn on the light after you turn the engine on so it won't short the bulb out. Also turn it off before you turn the engine off. If our DRLs are along with the Lo beams then please do remove the drl fuse. I was told our drl were in our hi so you should be safe with drl still on as long as the hi is still a halogen bulb.
post Aug 15, 2013 - 8:12 PM
trdproven
Joined Aug 2, '05
From Guam
usually see the ballast bad all the time, almost never the bulb. you have to test and swap parts to make sure though. Ive even seen HID bulbs light up but theres almost no light on the ground at night. What I did was sit over one headlight and it didnt really change or block any light so things can get weirder. when I replaced the bulb, it fixed the issue, it was actually the first and only time I had to replace a bulb.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: February 23rd, 2025 - 5:38 PM
