> 99 gt brake problem
post Aug 19, 2013 - 11:18 AM
Chas_23
Joined Aug 19, '13
From Pueblo Co,
So I hit a curb pretty hard in my 99gt. I cracked a rim and broke my rotor in half. But I got everything bAck to together but now I can't get my brakes to work properly. If anybody has any info to fix this please let me know. I already bled them but there is still very little braking.
Replies (1 - 4)
post Aug 19, 2013 - 11:58 AM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
check to see if your caliper piston isnt binding
I only want to be faster than the guy next to me.
post Aug 19, 2013 - 2:24 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
i would assume you bled them correctly. Did you remove the brake line when you were working on the rotor?
post Aug 19, 2013 - 5:31 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Define "not working properly."
Seized? Dragging? Piston won't extend? Soft pedal? Hard pedal?
That said, if you hit the curb hard enough to crack the rotor, you might want to check the condition of the backing plate (rears) and bracket. Bending those would change the geometry of the system.
post Aug 21, 2013 - 1:35 AM
RavenAegis45
Joined Jun 25, '08
From CA
QUOTE (Galcobar @ Aug 19, 2013 - 6:31 PM) *
I agree with ^^ check to see if any of the parts are bent, maybe go to a junk yard and pull some brackets and the backing plate off or even a whole hub and compare it to yours, if you hit the curb that hard and broke your rotor then the damage could have easily spread far from just the rotor, but on a side note also check your sliding pins and maybe even the caliper itself, it is possible to bend those as well if hit hard enough
Lo-Fi Version Time is now: December 2nd, 2024 - 1:27 AM
