> quick question on adding a turbo to a 5sfe
post Aug 24, 2013 - 7:59 AM
b22ri22an
Joined Jun 2, '10
From Davenport, Florida
I read through a lot of the stickies and a few threads but cant find these particular answers
Can you run a low boost say wastegate pressure about 7lbs on a stock ecu with no piggyback unit? Will doing so compromise your motors reliability?
If the answers were there in the stickies and I missed them I apologize, but it seems they just said its recommended but never said it could or couldn't be done without one if I read it correctly.
I'm not looking for tons of power just a little bit more then what i got. I'm about to have my 5sfe fully overhauled and I am considering putting a turbo charger but I want to keep the cost down. I know if I had the piggyback i could get a lot more the 7lbs on stock internals but the piggyback and hooking it up and tuning it is the part I can't afford the rest can be bought and installed rather cheaply (sub 500) and i can always add the piggyback later when I have more disposable income.
Replies (1 - 16)
post Aug 24, 2013 - 8:50 AM
no.
post Aug 24, 2013 - 10:07 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (Batman722 @ Aug 24, 2013 - 9:50 AM) *
no.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Aug 24, 2013 - 2:21 PM
^ I agree. I love spending less on mods too, but "cheap" and "aftermarket turbo" should never be used in conjunction.
post Aug 25, 2013 - 2:05 AM
b22ri22an
Joined Jun 2, '10
thanks for the straight forward answer, its what i assumed was the case but wanted to be sure.
post Aug 26, 2013 - 2:26 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
Can't be cheap when working with boost. Save up until you are ready.
post Aug 26, 2013 - 4:09 PM
you can run the stock ST185 turbo (ct26) using non turbo 7M-GE injectors and a USDM MR2 or ST185 MAP sensor.
post Aug 27, 2013 - 6:16 AM
b22ri22an
Joined Jun 2, '10
QUOTE (Smaay @ Aug 26, 2013 - 4:09 PM) *
on a stock 5sfe ecu? if so do tell more.... like I said I'm not looking for tons of power just more then what I got, I can't justify the piggyback, the cost of install or tune for 20 to 30hp
post Aug 27, 2013 - 7:58 AM
yes on the stock ECU. i HIGHLY suggest having a wideband O2 sensor to see if you are running lean.
post Aug 27, 2013 - 9:06 AM
b22ri22an
Joined Jun 2, '10
with that its time to start doing some homework and setup a parts list, thanks Smaay
post Aug 27, 2013 - 12:37 PM
Pfloyd09
Joined Jul 15, '13
From USA
QUOTE (b22ri22an @ Aug 27, 2013 - 10:06 AM) *
If you come up with something workable that you like, please do post the details. I have 2 GTs, and I'd like to do this to my 95 GT auto. The 5-speed is getting a 3S-GTE, but it would be nice to have a bit more pep in the auto for daily driving.
If anyone else has this info, please don't be shy. smile.gif Adding a low boost turbo to the 5sfe that works well with stock internals for under $1k would be very nice to do.
post Aug 29, 2013 - 9:37 AM
Syaoran
Joined Jan 4, '12
From US
Smaay is talking about this:
http://warp.scl.utah.edu/mr2/Turbo5sfe.html
This always leads to wanting more, which usually leads to kaboom.
post Aug 29, 2013 - 10:28 AM
^^^ yes there is more work involved. you need a 3S-GTE oil pan or modify yours for the oil return. you need to modify your exhaust. and get colder plugs. BKR7ES are a good plug.
post Aug 29, 2013 - 11:05 AM
QUOTE (Smaay @ Aug 26, 2013 - 5:09 PM) *
And run about 30-40 degrees of timing under boost with a setup like this, due to cutting your timing map in half.
post Aug 29, 2013 - 4:37 PM
Pfloyd09
Joined Jul 15, '13
From USA
QUOTE (Syaoran @ Aug 29, 2013 - 9:37 AM) *
That page is hosted on the UTAH.EDU site. Any chance some of you fine people are in the SLC Utah area? I am, and it would be very nice to have a 3S-GTE swap-knowledgeable guy near. smile.gif
post Aug 31, 2013 - 4:51 AM
b22ri22an
Joined Jun 2, '10
QUOTE (Syaoran @ Aug 29, 2013 - 10:37 AM) *
Like I said in the OP I'm not looking for a ton of power just a little extra, If I see 150-160whp i'd be damn happy
post Aug 31, 2013 - 8:23 AM
Syaoran
Joined Jan 4, '12
From US
Then follow that guide. A boost gauge and a wideband gauge are VERY recommended, as well as perhaps a SAFC piggy-back for fine tuning.
Lo-Fi Version Time is now: November 24th, 2024 - 11:21 AM
