> Starting problem, Starting problem
post Oct 24, 2013 - 2:14 PM
valerit1
Joined May 2, '06
From Nevada
My celica sometimes does not start on a key turn, starts ok after a delay. Normally, it is attributed to the starter contacts.
But sometimes the starter engages and turns, and then dies. Restart works. Battery good, no other issues.
What else to blame in this case?
Thanks!
Replies (1 - 19)
post Oct 24, 2013 - 8:38 PM
danmumo
Joined Oct 10, '13
From Ontario, Canada
I am not completely sure, but i had the same issue with my 5gen and it with time the starter died.
post Oct 24, 2013 - 8:49 PM
Syaoran
Joined Jan 4, '12
From US
I agree, it sounds like a dying starter.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Oct 25, 2013 - 3:22 PM
valerit1
Joined May 2, '06
From Nevada
I took it apart recently and the contacts are good. What other reasons may be for it to die?
post Oct 25, 2013 - 5:56 PM
blackliftback
Joined Mar 1, '12
From iowa
Check ground wire connections.
post Oct 29, 2013 - 12:30 PM
valerit1
Joined May 2, '06
From Nevada
Ground is fine. Anything else?
post Nov 3, 2013 - 3:10 AM
blackliftback
Joined Mar 1, '12
From iowa
QUOTE (valerit1 @ Oct 29, 2013 - 12:30 PM) *
Did you check all the ground wires? The thermostat, trans, engine, and battery ground?
post Nov 13, 2013 - 4:36 PM
Poonicus
Joined Apr 24, '13
From Tomball, TX
What about your distributor?
"As a professor of science, I assure you we did, in fact, evolve from filthy monkey-men." -Prof. Farnsworth
post Nov 13, 2013 - 7:18 PM
valerit1
Joined May 2, '06
From Nevada
Grounds are good. Once again - it doe not start several tries sometimes - then does. Runs absolutely perfect otherwise - how it can be the distributor? Anything else? Switches? Transmission/neutral? Any other?
post Nov 13, 2013 - 9:27 PM
blackliftback
Joined Mar 1, '12
From iowa
Auto or manual?
And when you say it takes a few tries before it starts, does it at least crank over but not start or does it do nothing?
post Nov 13, 2013 - 9:47 PM
valerit1
Joined May 2, '06
From Nevada
Auto. No cranking - until in cranks and starts. All warning lights lit - and nothing on a key turn. No starter clicking. Several tries - same.
And then it starts. Next time it can happen weeks ahead.
post Nov 13, 2013 - 10:40 PM
blackliftback
Joined Mar 1, '12
From iowa
Have you tried putting it in neutral and then starting it?
post Nov 14, 2013 - 4:53 PM
valerit1
Joined May 2, '06
From Nevada
Inconclusive. Frequently starts after several tries - nothing else.
post Nov 15, 2013 - 8:56 AM
blackliftback
Joined Mar 1, '12
From iowa
So did you try putting it in neutral and try to start it? Reading pwns me sometimes lol
post Nov 15, 2013 - 12:08 PM
valerit1
Joined May 2, '06
From Nevada
It may start if I put in neutral. Or may not. Or it may start if I do nothing. Couple of times when I put in neutral the starter span for a short time and died without starting. It has been doing it for many months, if not years! The frequency might have worsened, though.
post Nov 15, 2013 - 12:11 PM
valerit1
Joined May 2, '06
From Nevada
I replaced the starter relay. It is not the starter itself. All the warning lights are lit. Today it started after the 5th try - touched nothing but the key.
post Nov 15, 2013 - 12:25 PM
Perhaps stupid/obvious/unnecessary, but corrosion on the battery terminals?
post Nov 15, 2013 - 1:15 PM
blackliftback
Joined Mar 1, '12
From iowa
How does it do when you get it started and drive....
Example; when you are driving, does it act like neutral/wrong gear?
post Nov 15, 2013 - 1:21 PM
valerit1
Joined May 2, '06
From Nevada
I replace the battery a couple times while this happening.
QUOTE (SwissFerdi @ Nov 15, 2013 - 1:25 PM) *
post Nov 16, 2013 - 10:52 PM
valerit1
Joined May 2, '06
From Nevada
It is absolutely perfect, except this problem.
QUOTE (blackliftback @ Nov 15, 2013 - 2:15 PM) *
According to the Toyota wiring diagram - there are only 3 ground points - 2 on the front sidewalls, and one on the leftmost spark plug?
QUOTE (blackliftback @ Nov 3, 2013 - 4:10 AM) *
Lo-Fi Version Time is now: January 12th, 2025 - 8:40 AM
