Radiator |
Radiator |
Nov 17, 2013 - 2:58 AM |
Enthusiast Joined Sep 16, '13 From los angeles, CA Currently Offline Reputation: 0 (0%) |
What are the two ports on the bottom or the radiator for? i had to change my radiator because it cracked and when i was changing it i noticed there was two ports on the bottom that were capped off on my old radiator and had brass piping on the new radiator.. i took off the brass and capped the ports. just today the coolant started leaking in the area as one of the ports.. so i just want to know what they are for
Nov 17, 2013 - 9:58 AM |
They are for an auto trans cooler.
Nov 17, 2013 - 11:37 PM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
They are for an auto trans cooler. +1, the leak. You'll have to try and seal it with a silicone or some type of sealant. -------------------- |
Lo-Fi Version | Time is now: November 26th, 2024 - 7:44 PM |
