Enthusiast Joined Oct 3, '12 From san francisco Currently Offline Reputation: 0 (0%) ![]() |
I have no idea what it is and need some direction. I just noticed that this thing's wire was cut and doesn't go anywhere anymore. I don't know whether or not this is causing my car to sometimes stall when turning the wheel all the way to the left or right. I also occasionally drop from idle 1000rpm to 800rpm and it stays there. sometimes it will jump back to 1000rpm after a little driving but also goes back down.
sorry for the blurry pictures from my poverty phone lol ![]() ![]() |
yes that is an O2 sensor.
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '08 From Denver Currently Offline Reputation: 59 (100%) ![]() |
It looks like the wire is spliced back together. Is your CEL on?
You might pull the code and check to make sure the O2 sensor is the only code you have. If you can find the other half of the wire, it would be a good idea to splice it back together.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) ![]() |
Definitely try to find the other side of the wire and splice it back together. I dont know why they would even cut it. It should help your idling problems.
Lo-Fi Version | Time is now: February 22nd, 2025 - 3:34 PM |
