> hub options, what else can i use?
post Jan 15, 2014 - 11:32 AM
Fuzzyfo
Joined Nov 7, '12
From Puerto Rico
other than the celica st hubs, are there any other hubs i can use from other toyota vehicles?
Replies (1 - 19)
post Jan 15, 2014 - 11:56 AM
yes the camry hub, and convert to 5 x 114.3
post Jan 15, 2014 - 12:30 PM
Fuzzyfo
Joined Nov 7, '12
From Puerto Rico
what year camry? same vintage as the celica or can it the 97-2000 camry as well?
post Jan 15, 2014 - 1:21 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (njccmd2002 @ Jan 15, 2014 - 8:56 AM) *
Im going to do the conversion soon also. Here's the how to link for it.
http://www.6gc.net/forums/index.php?showtopic=80878
post Jan 15, 2014 - 1:35 PM
richee3
Joined Jun 29, '08
From Denver
I think he's wanting to stay 5x100 and get a replacement hub, not do a conversion.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 15, 2014 - 1:37 PM
ILoveMySilly97
Joined Mar 8, '12
If you don't want a conversion then Celica only. Maybe corollas but not sure.
post Jan 15, 2014 - 3:25 PM
Fuzzyfo
Joined Nov 7, '12
From Puerto Rico
im guessing theres some work to be done in the conversion
post Jan 15, 2014 - 3:55 PM
well in that case, just celica... part numbers on toyo, list some japanse curren, corona, and caldina... but these are the same..
why do you need one?
post Jan 15, 2014 - 6:05 PM
Fuzzyfo
Joined Nov 7, '12
From Puerto Rico
i need two for both sides and looking for the motor mounts. my celi is sitting at home getting a new rack and pinion installed and i might as well get everthing fixed while im at it. pepboys, autozone and advance auto dont have the hubs so.im looking for alternatives or see if anyone has em here
post Jan 15, 2014 - 6:09 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Fuzzyfo @ Jan 15, 2014 - 12:25 PM) *
QUOTE (Fuzzyfo @ Jan 15, 2014 - 3:05 PM) *
Since you're already replacing the hubs. I'd suggest just doing the conversion. The conversion is all bolt on. No mods are needed. The only mod you need to do is to press the front hubs out but either way you're still going to need to do that to replace the hub. Lol. Might as well do the conversion.
post Jan 15, 2014 - 6:22 PM
Fuzzyfo
Joined Nov 7, '12
From Puerto Rico
okay how about money wise? will the conversion cost as much as replacing them or a little more costly?
post Jan 16, 2014 - 12:32 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Fuzzyfo @ Jan 15, 2014 - 3:22 PM) *
Its all the same process. I'd expect to pay the same. Only thing is...if you don't have 5x114 rims then you need to go get a set.
Actually. I take that back. It costs about 150-250 more to do the conversion on your case. Since you'll need to buy new 5x114 rotors. But the total costs that I'm looking at for my conversion. Is roughly $500 for labor cost and parts.
This post has been edited by ILoveMySilly97: Jan 16, 2014 - 12:38 AM
post Jan 16, 2014 - 6:34 PM
Fuzzyfo
Joined Nov 7, '12
From Puerto Rico
maybe later down the road i'll do the conversion but right now i just need to get my celi running again. you think hubs from a 90-93 celica st would work?
post Jan 16, 2014 - 7:34 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Fuzzyfo @ Jan 16, 2014 - 3:34 PM) *
They should work. Why you changing the hubs? They usually don't go bad. just the bearing.
post Jan 16, 2014 - 8:20 PM
Fuzzyfo
Joined Nov 7, '12
From Puerto Rico
apperantly my hubs are broken. the bearings are good but the hubs are shot kindasad.gif and its only the right side hub but i might as well change both
This post has been edited by Fuzzyfo: Jan 16, 2014 - 8:21 PM
post Jan 17, 2014 - 2:08 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Fuzzyfo @ Jan 16, 2014 - 5:20 PM) *
That sucks. Well too bad I'm not doing my conversion yet. I would've sold it to you. Lol.
post Feb 3, 2014 - 9:51 PM
jimblah
Joined Feb 3, '14
From lockport ny
I also had to replace the hubs on my celica , after pulling
a set off my parts car to find out that they we also bad. The metal on the hub where the inner race contacts the hub wears down then
the hub doesn't fix tightly inside the bearing. long story short partsgeek.com has oem hubs cheaper than anybody else.
partsgeek.com are the cheapest hubs I could find , and when the arrived it was great to find out that they were oem
post Feb 4, 2014 - 10:31 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
If the hubs are bad, your bearings will most likely be gone/have signs of wear as well.
My Celica!
post Feb 16, 2014 - 9:14 PM
qatar11
From Lake Orion, MI
There is a bit a of chicken and the egg thing with the hubs and bearings... essentially wear in one will quickly wear out the other and they will destroy each other... you can try some junk yard cars but considering the price of *good* bearings (Timken, etc) you might want to fall on the grenade and get brand new hubs... the key is to get brand new axle nuts (there is a TSB on it) and make sure you keep those torque to spec.
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Mar 17, 2014 - 1:45 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
I've got a good set sitting in my basement. Nothing wrong with them just took them off to convert to 5x114.3 lug pattern. Pm me if your interested. I'll let the set of 2 go for $85 shipped
2001 Solar yellow Lexus IS300
Lo-Fi Version Time is now: January 10th, 2025 - 10:21 AM
