> Are they any DATALOGGING software options for 1994 OBD1 st?, Ive used MMCD, and LS1m software, what is there for the celica
post Jan 29, 2014 - 2:10 AM
hdnseek
Joined Jan 10, '14
From Des Moines
So with autox season coming up im in need for a datalogger for a 94 obd1 st. I have used MMCD software and custom built cable on a palm m515 on my old 92 stealth, i also used the same m515 palm with a custom built ls1m cable for my supercharged grand prix for aiding in tuning, so after doing some searching and not turning up many results im posting this up. Is there any custom built cables or datalogging options to use for a 94 obd1 st? Ive read on mro2c theres a russian built cable thats suppose to work with some russian software but theres not alot of info on it? Anyone have options or know of some?
Replies (1 - 4)
post Jan 29, 2014 - 1:18 PM
none that I know you, you will have to build the harness yourself and use a stand alone datalogger. Or use some sort of stand alone ECU that datalogs
post Jan 29, 2014 - 5:02 PM
type_r
Joined Jan 29, '14
From Serbia
ST202
post Jan 29, 2014 - 9:51 PM
hdnseek
Joined Jan 10, '14
From Des Moines
do the obd1 to obd2 converter cables work and may be able to use with elm scanner or something?
post Jan 30, 2014 - 12:13 PM
type_r
Joined Jan 29, '14
From Serbia
I have not tried obd1 to obd2 converter, but I think it does not work
None of the standard diagnostic program does not work whit TCCS obd1 standard
It is a specific "bit banging" protocol
the flow of data is slow refresh, I think two times per second, but the data is very useful
program and the scheme here ODB1
Lo-Fi Version Time is now: November 26th, 2024 - 9:41 PM
