Single 'click' when braking |
Feb 17, 2014 - 6:05 AM |
Enthusiast Joined Dec 9, '13 From Melbourne, Australia Currently Offline Reputation: 2 (100%) |
Since today, every time I brake firmly there is a single 'click' that comes from the drivers side wheels..
It doesn't click if I do a slow or gentle brake, only when it's a bit more firm.. I've tried in both forward and reverse and it does it.. Would anyone know what It could be? Brake pads moving or ball joint? Thanks -------------------- |
Feb 17, 2014 - 7:32 AM |
Enthusiast Joined Apr 12, '13 From Bulgaria Currently Offline Reputation: 53 (100%) |
When did this started happening, what did change?
Feb 17, 2014 - 8:17 AM |
I went on a 500km road trip 2 days ago, but no noises during then..
Only started today in the morning when I got in the car, (now its midnight) I jacked up the car and wiggled the wheel around to see if its the ball joint but there was no noises from moving it around.. I couldn't take the wheel off because my tire iron has gone missing, but after just wiggling the wheel around and driving around, now I notice it only happens about 1/5 times I brake and when it does its quiter than before.. Maybe its just dust, because the car is very dirty -------------------- |
Feb 17, 2014 - 10:03 AM |
i'd check your caliper bolts...
Feb 17, 2014 - 2:57 PM |
Enthusiast Joined Jun 25, '08 From CA Currently Offline Reputation: 0 (0%) |
i'd check your caliper bolts... I agree you should make the sure the Guide bolts are in good shaped/properly lubed, but on a side note if your using Semi-metallic pads they tend to be noisier than other materials, I used to run them and every so often I'd get this tiny creak/ping when I started braking. |
Nov 13, 2014 - 10:26 AM |
Enthusiast Joined Aug 17, '10 Currently Offline Reputation: 0 (0%) |
I have a similar problem at both sides and afer I checked it a lot I found that the inner break pads move inside the caliper.
I don't know if there is something missing from my brakes but it does it on both sides. I 've been thinking to replace the springs insight the caliper but do you thing this will be enough? And in case someone alse have similar problem if you ffell under the rear end and try to move the pads with your hand, you will replicate this sound without much effort. |
Nov 13, 2014 - 2:57 PM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
Does it happen on acceleration as well as braking?
I had this caused by worn out LCA bushings and it was a pain in the ass to find. Something you could easily rule out. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Nov 14, 2014 - 8:44 AM |
Does it happen on acceleration as well as braking? I had this caused by worn out LCA bushings and it was a pain in the ass to find. Something you could easily rule out. No man just under braking. I can feel the pads moving by pushing it with my handm there is a lot of play in my calipers, forcing them to move I can replicate the exact sound. |
Nov 27, 2014 - 1:41 AM |
Enthusiast Joined Jul 24, '08 From Canoga Park CA. Currently Offline Reputation: 0 (0%) |
Does it happen on acceleration as well as braking? I had this caused by worn out LCA bushings and it was a pain in the ass to find. Something you could easily rule out. No man just under braking. I can feel the pads moving by pushing it with my handm there is a lot of play in my calipers, forcing them to move I can replicate the exact sound. Mabey your wire springs came out they hold the pads from moving and rattling. |
Nov 27, 2014 - 4:32 PM |
Enthusiast Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
There is a Toyota tech bulletin for a single click in the brakes, it's caused by the loose fitting pads. When you back up and brake, they shift back and the next time you brake going forward, they click against the mount. Toyota's fix was add brake grease to the pad mounts to lessen the noise.
I'm wondering if some brass shim stock to get a better fit may be do-able? http://www.celicahobby.com/tech/tsb2/TSB_clicking_noise.pdf |
Dec 10, 2014 - 8:44 AM |
Enthusiast Joined Jul 1, '14 From Hawaii Currently Offline Reputation: 3 (100%) |
Since today, every time I brake firmly there is a single 'click' that comes from the drivers side wheels.. It doesn't click if I do a slow or gentle brake, only when it's a bit more firm.. I've tried in both forward and reverse and it does it.. Would anyone know what It could be? Brake pads moving or ball joint? Thanks Its the pads moving, try different pads, or you could also try 7th gen calipers and pads as i haven't heard of the problem with those. Edit: My bad didn't read the last reply lol This post has been edited by Noahwhite2014: Dec 10, 2014 - 8:45 AM |
Lo-Fi Version | Time is now: December 2nd, 2024 - 10:41 AM |
