> front and rear motor mounts, anything else that's gonna make a clunk ?
post Mar 10, 2014 - 11:16 AM
VavAlephVav
Joined Dec 3, '13
From Missourah
so I finally got some time with the right weather to install the rear motor mount that's been in my trunk for a month now.
I had replaced the front mount just before it got cold and had not time to do the rear.
and the rear was a freaking Chore ! finally I figured out that I needed to take loose the bottom of the front mount too and remove the whole center support
so that I could get the rear mount in/out, thought I was stuck for a minute.
So I know the front and rear mounts are new, and the right side is a solid mount (had that apart when I did the timing belt)
I have not replaced the transmission mount on the left side, although it doesn't look bad, but maybe I can't see it until I really take it all the way out.
but the deal is even after replacing the rear I still get a bit of a clunk when I shift. Is there anything else that could cause it or do you think its just that
transmission mount? or is it something inside the transmission?
Bad motor mount is Bad M'kay
Bust a Deal; Face the Wheel.
Replies (1 - 2)
post Mar 10, 2014 - 4:29 PM
http://www.6gc.net/forums/index.php?showtopic=39891
post Mar 10, 2014 - 6:14 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
thanks - after driving it today I think it's not too bad at all, probably just needs a new trans mount as well. ...idk if I'm in a hurry to get back under there and put inserts in there, I kinda like it a little flexible.
Lo-Fi Version Time is now: December 3rd, 2024 - 6:49 PM
