Couple of parts. Will they fit? |
Jun 9, 2014 - 8:40 AM |
Enthusiast Joined Jul 8, '13 From Norway Currently Offline Reputation: 0 (0%) |
Wow, it's been a long time since I posted anything here at all. The last year my Celi has been in my driveway due to rod knocking and it's about time to fix her up.
I know I have to change the engine 8 hour drive from Norway to Sweden to pick it up, but that is all set. What I DO have a question about, do these parts here fit? (Lefthanded 1994 Celica ST202 with 3SGE (175hp) and Superstrut. Front CV axle drive shaft with ABS: http://www.rpmgarage.com/new/detail/?tid=24567 Rear brake discs: http://www.importcarparts.co.uk/parts_info...&searchKey= Front brake discs: http://www.importcarparts.co.uk/parts_info...&searchKey= Front brake pad set: http://www.importcarparts.co.uk/parts_info...&searchKey= Handbrake shoes: http://www.importcarparts.co.uk/parts_info...&searchKey= Rear brake pad set: http://www.importcarparts.co.uk/parts_info...&searchKey= Hand brake cable: http://www.importcarparts.co.uk/parts_info...&searchKey= If some parts do not fit, could you please point me in the right direction, please. Would mean the world to me to get my Celi up and running before fall! -Simon -------------------- |
Jun 10, 2014 - 5:41 AM |
No pointers? Don't want to spend a grand on something that might not work
Jun 10, 2014 - 6:07 AM |
Well, the site says the brake stuff is for your particular model so you should be ok. The axles on the other hand won't work. They're for the GT-Four that has the E154? transmission, while your car has the S54 transmission I believe.
Jun 10, 2014 - 11:07 PM |
Thank you for your answer Clear things up a bit!
Lo-Fi Version | Time is now: January 10th, 2025 - 11:45 AM |
