7AFE rebuild - HP Engine Kits, a lot of questions |
Aug 8, 2014 - 5:21 AM |
Enthusiast Joined Sep 27, '12 From Athens, Greece Currently Offline Reputation: 0 (0%) |
Good day all,
I live in Athens, Greece and I have a '95 ST (7AFE motor) with just under 190.000 km on the clock. The engine is compltely stock other than a somewhat sporty (read: louder) muffler that was on the car when I got it. I am considering rebuilding the engine in the very near future. So I thought while I'm at it it might be a (very) good idea to get some extra hp out of it. I'd neither want an engine swap nor fit a turbo. I came accross the products of www.importperformanceparts.net - their "HP Engine Kits". I think their asking prices are pretty good so I was tempted. I looked however at the contents of their kits and they included: Complete Gasket Set MLS Head Gasket (their Dutch dealer sells copper gasket - is that any better?) Wiseco Pistons - Your choice: (81, 81.5, 82mm bore and any comp ratio) Performance Rings Performance Wrist Pins TOGA HP Main Bearings TOGA HP Rod Bearings Timing Belt Freeze Plugs Thrust Washers From the above most of any hp upgrade would come from the raise in compression ratio. I mean they don't include anything concerning the intake, exhaust or engine management. They don't advertize hp results, but they claim the customer should expect something like +40hp (MIN) and they advertize the results on their test car (a 1995 Acura LS 1.8, Stock HP 140) which resulted in +38hp with the engine kit alone (source: http://www.importperformanceparts.net/impo...pek-story.html) Is this possible? I mean can you get some 35% more power just by increasing compression (I mean within driveable limits)? Even if compression is increased to 10.5 or even 11:1 (gasoline in my country has minimum 93 RON), that would be some 10-15% above stock. And can the stock engine management handle it? Does anyone here have any experience with these kits? What is the consensus? In addition with the above and as boys will always be boys... I thought, why not add a header, maybe a cold air intake and ... just ... maybe ... a pair of cams. It was pretty difficult to find headers for the celica 7AFE, but I did find these: DNA: http://www.amazon.com/COROLLA-CELICA-STAIN...E/dp/B00CO7A6Z6 and OBX: http://www.2kracing.com/Product/18421.html What do you think of them, any good? (...obviously the DNA is considerably cheaper + wich free shipping to my door... tempting... very tempting...) And can a Corolla 7AFE header fit and work on a Celica 7AFE engine? I don't worry too much about the CAI as I did find some (albeit expessive) or I cound improvise along the DIY lines of this forum If it was difficult to source headers, it was impossible to find any cams. I suppose I could buy a pair of secondhand ones and have them re-profiled here (we have a pretty good cam specialist here) - but really are there no cams out there for the 7AFE? And if I have stock cams reground - to what spec? Any ideas? Coupled with the HP Engine Kits have mentioned above resulted in some crazy NA hp on Import Performance Parts' test car... A lot of questions I know... I'd appreciate your advice. Thanks in advance Manos This post has been edited by Manos: Aug 8, 2014 - 6:40 AM |
Aug 9, 2014 - 3:54 AM |
Anyone?
Aug 9, 2014 - 4:17 AM |
sorry buddy, only like a few people have modded their 7a they can be counted with the fingers in one hand. you may get a response, but its not going to be quick. be patient, someone will chime in.
technical questions this forum will answer very quickly 1- Will an old camry key open my celica 2. Did Box ever get a car? 3. Why box no longer likes a miata? 4. Is stickerbomb cool anymore? 5. anyone else have turtles? 6. can i use my car for deliveries, and do a 1jz swap... lol, but most knowledgeable people are not as active, so you answer may be a bit delayed. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Aug 11, 2014 - 9:19 AM |
Thanks for the reply. I will be patient and wait for someone to chime in as you say.
In the meantime, I contacted the Dutch dealers of importperformanceparts.net who, in so many words, all but confirmed that (a) they cannot guarrantee what sort of power increase their kits will deliver and (b) it is indeed only the increase in C/R that will provide that increase. On the above basis, if I go from 9.5:1 to 10.5:1 I should anticipate some 10% increase or 12 extra HP. Suddenly it doesn't sound like such a brilliant investment... I'm for importperformanceparts.net themselves to respond and if things don't change significantly (and they shouldn't really...) then I might just go for the cheapest rebuild of the engine (general cleaning and replacement of rings etc consumables) and pretty much just refresh a stock engine. Before anyone jumps on me, I do know very well that horsees (hp) aren't peanuts, they don't come for free, there is no magic and there are valid means of obtaining extra hp. I would like something like that though: http://www.toyotanation.com/forum/130-7th-...-8-seconds.html The responses on that thread were enthousiastic at best... M. |
Aug 11, 2014 - 11:09 AM |
I probably have the most experience in modding the 7A. I can tell you this, raising the CR will gain you 2 HP, maybe. You can make more power buy turning the distributor clokwise by advancing the timing to about 15 degrees. run better gas and it will feel so much better.
I dont trust any knock off gasket kits. get the OEM rebuild kit from a dealer if you plan on rebuilding. This is a 7A-FE, its not going to make power. PERIOD! dont spend a ton of money for mods you dont need. I turboed a 7A. the turbo system was sound, we just never spent any time with the tuning. A properly tuned 7A will support 250HP reliably. -------------------- 2001 Celica GT-S Turbo
Lo-Fi Version | Time is now: December 4th, 2024 - 2:28 PM |
