Redtop 3s-ge beams engine management system |
Sep 27, 2014 - 7:24 PM |
Enthusiast Joined May 8, '14 From Houston Currently Offline Reputation: 1 (100%) |
Hey all so im wondering what all my options are for a ems. Im not turboing yet, but i can get a few more horses with a decent tune. Are the ems specific to engines or not? If so what are some decent ones.
Thanks |
Sep 27, 2014 - 8:16 PM |
universals are not specific, you will gain a few horses if you can tune the VVT.
Sep 27, 2014 - 11:52 PM |
Enthusiast Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
You can get a Power Enterprise CAMCON controller for it. Its essentially a piggyback that has vvti tuning capabilities.
As for EMS youll have to dig around for one. Ive been in contact with ATS and am looking to help get the ball rolling on finishing up their EMS for the Beams. -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Sep 28, 2014 - 11:08 AM |
the CAMCON only tunes VVT, it doesnt have timing or AF tuning
Sep 28, 2014 - 1:25 PM |
the CAMCON only tunes VVT, it doesnt have timing or AF tuning http://www.power-enterprise.co.jp/USA/prod...mcon/camcon.htm It does to AF. QUOTE CAMCON CC-111
The CAMCON-T allows you to take unrestricted control of your VVT-i valve timing into your own hands. Along with this, the ability to control your A/F will allow you to more efficiently and precisely tune your vehicle giving you a higher level of performance and fuel economy. TOYOTA VVT-i & VVTL-i The CAMCON-T controls the VVT-I timing +/- 20 degree in 15 different points of 500rpm increments within 2000rpm to 9000rpm Range. A/F is controlled -10% to +20% in 17 different points of 500 rpm increments within the range of 1000rpm to 9000rpm. Easy Installation -------------------- |
Sep 28, 2014 - 3:34 PM |
Enthusiast Joined May 23, '12 From northridge,CA Currently Offline Reputation: 3 (100%) |
anything useful for 3d gen 3sge?
Sep 28, 2014 - 8:51 PM |
Plug in remapped ecus such as Tom's, SARD, C-One, blitz, IMec off the top of my head. The company's play around with the ignition timing, fuel maps, remove the speed limiter (rather than moving it high) & the rev limiter. They use the factory ecu, to reprogram, & there are no additional ports to make changes down the road, unless you have a cable & the tuning software - Which will be very unlikely to get a hold of.
Sep 28, 2014 - 8:55 PM |
the CAMCON only tunes VVT, it doesnt have timing or AF tuning http://www.power-enterprise.co.jp/USA/prod...mcon/camcon.htm It does to AF. QUOTE CAMCON CC-111 The CAMCON-T allows you to take unrestricted control of your VVT-i valve timing into your own hands. Along with this, the ability to control your A/F will allow you to more efficiently and precisely tune your vehicle giving you a higher level of performance and fuel economy. TOYOTA VVT-i & VVTL-i The CAMCON-T controls the VVT-I timing +/- 20 degree in 15 different points of 500rpm increments within 2000rpm to 9000rpm Range. A/F is controlled -10% to +20% in 17 different points of 500 rpm increments within the range of 1000rpm to 9000rpm. Easy Installation well Ill stand corrected. However i highly doubt the changes you make will stay. Just like why S-AFC wont work on 7th gen. Now it might work on a Blacktop or redtop. -------------------- 2001 Celica GT-S Turbo
Oct 5, 2014 - 3:01 AM |
Damn rusty, we r so limited =\ my cousin and i, found an apexi fc comp, for his celica gts 00 2zz brand new from a tuner shop that had it aside for a while, got it for 350$ usd some damn luck
Oct 5, 2014 - 3:31 PM |
Thats just the plug in (reflashed ecu's) off the top of my head, I'm sure there are a couple more, thats not including piggyback ecu's either that can work.
Oct 5, 2014 - 10:21 PM |
Damn rusty, we r so limited =\ my cousin and i, found an apexi fc comp, for his celica gts 00 2zz brand new from a tuner shop that had it aside for a while, got it for 350$ usd some damn luck you scored a 2ZZ-GE Power FC for 350? dude you totally stole it!!!! thats a great deal. I have one in my GTS monster This post has been edited by Smaay: Oct 6, 2014 - 8:31 AM -------------------- 2001 Celica GT-S Turbo
Oct 5, 2014 - 11:17 PM |
i got power apexi fc computer
act clutch kit and fidanza flywheel all brand new in boxes for 600 |
Oct 6, 2014 - 8:32 AM |
i got power apexi fc computer act clutch kit and fidanza flywheel all brand new in boxes for 600 THIEF!!!!!!! Id get rid of that ACT clutch. sell it to get a Southbend. -------------------- 2001 Celica GT-S Turbo
Oct 6, 2014 - 2:43 PM |
well not even sure if that clutch will work, did not look into it, it was a customer that ordered all that for 2zz swap with 5spd on a mrs
Lo-Fi Version | Time is now: November 23rd, 2024 - 4:17 AM |
