Enthusiast ![]() Joined Feb 4, '04 From Tampa Currently Offline Reputation: 0 (0%) ![]() |
Installed a modified civic short ram intake on an ST but i noticed a sensor on the stock intake. There is no place to fit on the new intake. What should i do? I was told to stick a resistor in the plugs. Will this take care of the problen??
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) ![]() |
drill a hole and stick the grommet from the stock intake box in the hole and push in the temp sensor.
-------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
![]() Enthusiast ![]() ![]() ![]() Joined Aug 29, '02 From Dallas, Tx Currently Offline Reputation: 0 (0%) ![]() |
Yup. And like 97sccelica said, its not a mass airflow sensor, its and intake temperature sensor.
thanks for the info, i was going to drill a hole to make the sensor fit, but what about the resistor fix?? Thats what i have in there now and it seems to work fine. Is this bad for the engine???
its a hack mod,
its best for the ecu to kow the temp of the air going into the engine. get the sensor back in, but for now, your ok -------------------- 1994 Celica GT4 WRC Edition
Yeah, definitely drop the resistor. I doubt it will on a 7a because of the way the ecu works, but it very well could do damage to your engine.
Enthusiast ![]() ![]() Joined Jan 22, '04 From bellingham, WA Currently Offline Reputation: 0 (0%) ![]() |
in the future just buy an intake for a 93-97 corolla, lol
Enthusiast ![]() Joined Feb 5, '04 From Alhambra, Illinois Currently Offline Reputation: 0 (0%) ![]() |
I had the same problem the other day. Just drill a hole and put it in!
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jun 10, '03 From FL Currently Offline Reputation: 0 (0%) ![]() |
why did i not have one of those
![]() Enthusiast ![]() ![]() ![]() Joined Nov 27, '03 Currently Offline Reputation: 0 (0%) ![]() |
Um...... dude thats not good. I believe that all cars have those. Check to see if there are any loose hoses or wire connectors that are just hanging around. If not then wtf? lol anyways you might want to look all around for that. |
thanks guys, i have drilled the hole and replaced the sensor, if i knew a corolla intake would fit i woudl have used that, but at the time I didnt, damn, anyway, the intake still works well, so no problems, just had to put a little more manpower into it.
Lo-Fi Version | Time is now: February 24th, 2025 - 2:02 AM |
