Enthusiast ![]() ![]() Joined Jul 1, '14 From Hawaii Currently Offline Reputation: 3 (100%) ![]() |
The fuel gauge needle is difficult to move by hand compared to the temp gauge needle. Still works just takes about 2-3 minutes to get to full when i fill up a tank from near empty. Is everyone else's the same way? This is the second fuel gauge i popped in and they both take the same amount of time.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 23, '12 From Warrior, AL Currently Offline Reputation: 0 (0%) ![]() |
Not sure why you're trying to move things by hand, but it sounds like your fuel level float is sticking some.
Not sure why you're trying to move things by hand, but it sounds like your fuel level float is sticking some. Lol i moved it by hand to reset the needle to empty without having to drain my fuel tank Does your fuel gauge drop to empty when you shut the car off? Or does it stay at the level your gas is at when the car is off as well? |
![]() Enthusiast ![]() ![]() Joined Jan 30, '14 From Cortland NY Currently Offline Reputation: 5 (100%) ![]() |
It's not the best idea to move the temp or fuel needles by hand as it could mess with their calibrations.
However to answer your question, the fuel needle will stay at a constant to where your fuel level float was last when the car was on and depending how low your tank level was it could take a minute or two to show full again. This post has been edited by igpx12: Jan 24, 2015 - 11:25 PM -------------------- 1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool. |
I always kept mine between the 1/4-1/2 mark so it may take some time to go from empty to full, though I wouldn't imagine it'd take too terribly long.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) ![]() |
When I fill up, it takes a couple minutes to get to the "full" level on the guage, it doesn't go up instantly, if that's what you're asking.
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
![]() Enthusiast ![]() ![]() ![]() Joined May 10, '14 From Tulsa, OK Currently Offline Reputation: 5 (100%) ![]() |
My car does the same and I have 96 ST.
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '08 From Denver Currently Offline Reputation: 59 (100%) ![]() |
Mine has always been slow as well.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Dec 3, '13 From Missourah Currently Offline Reputation: 0 (0%) ![]() |
Yes this is normal behavior it just takes a few minutes for the reading to change when you fill it up.
-------------------- Bust a Deal; Face the Wheel.
I guess it was a good thing I never went to empty and then filled up, it'd drive me crazy having it move so slow. Of course now I have the opposite problem.
![]() -------------------- 2001 Miata LS 5-speed
![]() Enthusiast ![]() Joined May 13, '14 From Savannah, GA Currently Offline Reputation: 0 (0%) ![]() |
Yeah think this is pretty common, mine is the same way. But my car also starts sputtering and stalling once I get down to a 1/4 tank, then it only takes 8 gallons to fill up. Guessing it has to do with the fact that the previous owner had the gas tank replaced.
I guess it was a good thing I never went to empty and then filled up, it'd drive me crazy having it move so slow. Of course now I have the opposite problem. ![]() It does it any time you fill up, not just from empty, as I never let it get that low ![]() -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Lo-Fi Version | Time is now: February 21st, 2025 - 7:43 AM |
