> Climate control cable location on control lever.
post Feb 12, 2015 - 11:25 PM
Alleyoop
Joined Nov 20, '14
From Central Texas
I removed my climate control from my console to facilitate carpet replacement. I managed to disconnect the cables from the inside mounting bracket and holes. I could not find the paper I wrote the location of the cables on, so I don't know which hole the black cable goes in and which hole the blue cable goes in. I need to find out where the cables go on the lever. Can someone help me with the locations? I did search, but only found info re the disconnect under the hood and under the dash.
Thanks in advance
Replies (1 - 6)
post Feb 13, 2015 - 1:36 PM
msk59
Joined May 10, '14
From Tulsa, OK
I am at work so when I get home I have one pulled from my car and will take a picture and send it to you or describe it to you. So if you can wait till this evening I can look up for you. On the othersider/engine side the black one is the longer one and goes in the engine bay. The blue one goes near the accelarator pedal.
post Feb 13, 2015 - 2:16 PM
PegGTS
Joined Apr 15, '13
From Winnipeg, MB, Canada
The blue one goes here behind the center console, to the right of the pedals.
The black one comes through the firewall and right here, behind the engine.
2007 Impreza 2.5i - Daily
1994 Camry - Sold
1994 Celica - Sold :(
Click here to see my progress thread!
post Feb 13, 2015 - 3:35 PM
On th control
post Feb 13, 2015 - 6:55 PM
msk59
Joined May 10, '14
From Tulsa, OK
Thanks Norberto. I just got home from work.
post Feb 14, 2015 - 2:37 PM
Alleyoop
Joined Nov 20, '14
From Central Texas
QUOTE (Alleyoop @ Feb 12, 2015 - 11:25 PM) *
Thanks in advance
Wow, what a difference a little knowledge makes. I again removed the climate control module from the console after disconnecting the 2 cables and attaching a wire to the black one for retrieval. I did have them reversed on the module and it was a simple matter to swap positions this time.
Thanks again for the assistance.
post Feb 14, 2015 - 2:39 PM
Alleyoop
Joined Nov 20, '14
From Central Texas
guys, sorry my responses are taking so long to get posted. I guess I am still a probie.
Lo-Fi Version Time is now: November 23rd, 2024 - 1:19 PM
