> 1mz celica front spring rate
post Mar 25, 2015 - 5:13 AM
ST204R
Joined May 27, '08
From Oz
Hey all you guys with a 1mz / 3mz swapped celica - what spring rate are you running on your coil springs? I'm not sure if my 4 cyl sports springs have sagged with age or the extra weight of the v6?
Cheers
1MZ-FE 3.0L QUAD CAM V6
E153 5SPD MANUAL
GT4 FRONT END
Replies (1 - 7)
post Mar 25, 2015 - 8:29 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
snapshotgt I think the members name is who did a V6 had a little bit of info on his strut and spring setup for his swap. Are you looking for coilover spring rate or spring rates for spring/strut setup?
エキサイティングカーレーシングチーム!
post Mar 25, 2015 - 1:21 PM
im using OEM struts and springs. i havent noticed any sag. Im willing to bet that a 1MZ/3MZ with a 5 speed weighs about the same as a 5S with an auto trans. im sure its negligible
This post has been edited by Smaay: Mar 25, 2015 - 1:22 PM
post Mar 25, 2015 - 5:13 PM
Box
Joined Feb 23, '12
From Warrior, AL
^Yup. The 1MZ is all aluminum whereas the 5S is an iron block with aluminum head, so the weight difference is closer than you'd think.
2001 Miata LS 5-speed
post Mar 26, 2015 - 2:20 AM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Yea. You shouldn't have trouble. Iirc the 1mzfe is about the same weight as the 3sgte.
post Mar 28, 2015 - 2:02 AM
ST204R
Joined May 27, '08
From Oz
Thanks guys - I guess my springs have just sagged with age then. They seem soft as and if I slam the brakes on the nose dives like crazy. Added to which I can't go over a bump in the road faster than 40km an hour or the front end bottoms out. I'll see if I can look up snapshotgt's post re suspension setup.
E153 5SPD MANUAL
GT4 FRONT END
post Mar 28, 2015 - 6:16 PM
Box
Joined Feb 23, '12
From Warrior, AL
If you're using cheapo springs they'll always sag and give out eventually. Might look into coil-overs.
post Mar 28, 2015 - 10:46 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (ST204R @ Mar 28, 2015 - 3:02 AM) *
I think your struts might be blown. Sounds more like that than the springs sagging.
If you push down on the front of your car and it keeps bouncing, then they're blown.
This post has been edited by mkernz22: Mar 28, 2015 - 10:46 PM
Lo-Fi Version Time is now: November 29th, 2024 - 11:53 AM
