> 7g seats in a 95 gts?
post Apr 15, 2015 - 7:32 PM
doory100
Joined Jun 21, '14
From Ottawa, Ontario, Canada
7g seats in a 95 gts. Will you they fit??
Replies (1 - 19)
post Apr 15, 2015 - 8:08 PM
cheela
Joined Feb 2, '07
From Berlin, WI
I don't think they will fit a 95 without some modification or welding.
If you can find the 96-99 seat rails, it'll bolt right up to them.
http://www.6gc.net/forums/index.php?showtopic=83840
post Apr 15, 2015 - 9:12 PM
doory100
Joined Jun 21, '14
I'll make them fit!!
post Apr 15, 2015 - 9:15 PM
Box
Joined Feb 23, '12
From Warrior, AL
From '94-99 the holes in the floorboard are the same, just how the seat pans are and how the rails are changed along with the belt buckle. Can't remember exactly, but I think the thing to do is take the 7GC seat back and it fits directly onto the frame and then use the 7GC cover and cushion on the '96-99 seat pan/rail.
2001 Miata LS 5-speed
post Apr 15, 2015 - 9:22 PM
doory100
Joined Jun 21, '14
If not I can just plug weld them to the floor.
post Apr 15, 2015 - 9:40 PM
doory100
Joined Jun 21, '14
Are 96-99 Camry seat pans the same by chance? I'm guessing not...
post Apr 15, 2015 - 9:42 PM
1994Celica
Joined Aug 5, '09
From West Texas, USA
Swap the seat pans and that's it.
JDM Part King
post Apr 15, 2015 - 10:02 PM
Box
Joined Feb 23, '12
From Warrior, AL
It'd be easier to try and get the 7GC pans onto the '94-95 rail than trying to get the 7GC rail to work with 6GC floorpans.
post Apr 16, 2015 - 5:11 AM
doory100
Joined Jun 21, '14
Maybe a couple washers or somethig to lift them up? I got both seats in great shape for $30 CAD!!
This post has been edited by doory100: Apr 16, 2015 - 5:14 AM
post Apr 16, 2015 - 8:43 AM
richee3
Joined Jun 29, '08
From Denver
To use 7gc seats with 94-95 seat rails, there is some cutting and welding required. It's easiest to find a set of 96-99 seats to use as donors for the seat pan and rails. The Camry seats would make even more work than using the 94-95 rails.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Apr 16, 2015 - 4:36 PM
1994Celica
Joined Aug 5, '09
QUOTE (richee3 @ Apr 16, 2015 - 9:43 AM) *
You don't have to weld. I just swapped pans over in mine and it worked well.
JDM Part King
post Apr 16, 2015 - 7:24 PM
richee3
Joined Jun 29, '08
From Denver
For the 94-95 seats, you need to do some welding. The seat pams are completely different from the facelift seats.
http://www.celica-club.co.uk/wiki/index.ph..._seats_in_Gen_6
The 96+ seats are much easier to work with, just bolt the 7gc seat cushions to the 6gc seat pan and rails.
1998 Celica GT-
BEAMS Swapped.
post Apr 16, 2015 - 7:47 PM
1994Celica
Joined Aug 5, '09
QUOTE (richee3 @ Apr 16, 2015 - 8:24 PM) *
When I did mine I didn't weld at all and I have 94 seats. I just swapped the pans over and made them work. I don't remember exactly what I did bit I know I didn't weld.
JDM Part King
post Apr 16, 2015 - 10:50 PM
Box
Joined Feb 23, '12
From Warrior, AL
Perhaps drilled the pans out to match the rails? Would be my thought anyway.
post Apr 16, 2015 - 10:57 PM
1994Celica
Joined Aug 5, '09
Maybe I honestly don't remember exactly. My dad helped me with it, I know for sure we didn't weld. I know we didn't weld, as I know we used my 94 seat pan. I'll try to get some pictures tomorrow of it.
JDM Part King
post Apr 16, 2015 - 11:20 PM
Box
Joined Feb 23, '12
From Warrior, AL
I once tried replacing cushions on my '95 seats, but the replacement cushion was for '96-99. How they changed the cushions it just wouldn't work, most of the cushion would've needed shaving away to maybe fit.
This post has been edited by Box: Apr 16, 2015 - 11:20 PM
post Apr 17, 2015 - 9:28 AM
cheela
Joined Feb 2, '07
From Berlin, WI
probalby easiest way would be what box said, drill out the pans to match.
post Apr 17, 2015 - 12:32 PM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
The seat back is a straight forward swap. When i did mine, I only removed the upholstery from the 7thgen and placed it over the 6th gen cushion. Nice and tidy and less then 2 hours of work for both seats to be done.
Anyone telling you to cut/weld/drill to make it work, obviously never tried for themselves (no offense intended)
JDM ST205
post Apr 17, 2015 - 1:19 PM
1994Celica
Joined Aug 5, '09
Took pics of mine. I'm pretty sure I used the 7th gen cushion on the 6th gen seat pan. I didn't drill and I didnt weld. Here's pics of my passenger seat.
JDM Part King
post Apr 17, 2015 - 2:48 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (nsxtypeR @ Apr 17, 2015 - 12:32 PM) *
That's why we've all obviously swapped seats in our cars at one point or another. rolleyes.gif
Lo-Fi Version Time is now: December 3rd, 2024 - 9:13 PM
